Question about Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,
Rapid heat GPH002 troubleshoot - Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,
St 9400c keeps cutting out and turning on rapidly boiler will not heat properly
rapidly? seconds or minutes.
Make sure you select hot water boiler in the thermostat setup. That can cause short cycling. Boiler need a longer cycle range. If not, remove stat and jump wires, Isolate the problem, is it stat or boiler?
Sep 23, 2014 | Heating & Cooling
Can Jacuzzi Rapid Heat inline heater be installed upside down?
You do not want to install any heater upside down because if any debris gets inside the heater pressure switch while it is running it will NOT shut off once the pump shuts off.
Rod
US Parts Center
888-521-6183
Feb 17, 2013 | Jacuzzi RapidHeat In-Line Heater U395000 [...
My nokia 6300 phone become heat during charging.and battary is also discharge rapidly
Hi
not heat but warm battery during charging is normal...but if discharges rapidly your battery may have reached the end of life..before buying a new battery pls make sure that your charger is ok...you can test it with another nokia with same charging plug..all the same on Nokia..
Hope this helps!
Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 21, 2011 | Nokia 6300 Cell Phone
Hello, a few months ago I installed a jacuzzi tub with a Rapid Heat heater. I'd like to clean the tub either by the bleach/detergent method or the granule cleaning packet method. My question is should I...
Any recommended (see the tub instructions) cleaning product should be fine in the heater -- and the higher temperature of the "cleaning solution" should enhance the process. Just be sure to flush the tub's entire system with clean water before you bathe in it again!
Dec 01, 2017 | Jacuzzi S750000 Black RapidHeat In Line...
1993 Honda Civic rapid heating
Sounds like your electric cooling fan(behind the radiator) is not functioning. The thermostat might not be working,making the fan
not come on at all. I once put a toggle switch in my dash,when I had
an old CRX, just to turn on the fan, or it would overheat.
Mar 29, 2010 | 1993 Honda Civic 4 Door
Burner clicking on and off rapidly when reaching restart temp.
the gas orifices may be plugged try to poke them out with a fine wire . shyt off power and gas before cleaning as you don't want to be burned
Dec 13, 2009 | Heating & Cooling
Engine rapidly overheats,coolantvery near boils
Most likely the thermostat. The heater bypasses the thermostat. If the thermostat is blocked the only cooling is via the heater matrix. To check start the engine with the heater off and put your hand on the thermostat housing when the thermostat opens you should feel the housing get hot. If it doesn't the thermostat is faulty.
Aug 29, 2009 | 1998 Ford Escort
Rapid Heat Bath Heater - indicator light on but not heating water
Bathtub heaters will not produce the heat out a the jets like you would feel coming out of a return jet in a swimming pool.
Bathtub heaters will ONLY maintain whatever temperature water you put in there. they only heat 1-2 degrees an hour. that is for a 1500 watt heater. Many heaters today are only 650 watt or perhaps 700 watt.
Feb 21, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Heated wiper fluid light flashes rapidly
take it back to the dealer there been a Safety Recall Notice for the Heated Washer Fluid.
it says that GM will install a wire harness with an inline fuse, and it will be installed at no charge. It also says that parts should be available on or after November 1, 2008.
Aug 05, 2008 | 2007 GMC Yukon
Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools, Logo
599 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
