Actually SGN30S0
Three ofthe four burners ignite fine. They click twice and they seem to lighton the second click. For the fourth burner, it clicks only once anddoesn't like usually. Every once in a while, it clicks twice and lightsproperly. Actually the working ones continue to click if you leave theknob in the ignite mode. The bad one does not--there is only the firstclick. I tried the bad one again just now and it worked fine. They Itried it again and it didn't work. What do you think needs to bereplaced or adjusted? Thank you! Ron Cohen
SOURCE: Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
SOURCE: Thermador 30" gas cooktop SGCS304RB
You have defective potentiometer. The cost for parts is about $125.00 plus labor
SOURCE: Thermador cooktop won't light it has the ignite
try to clean a little bit the head of the sparkler and push the button for gas a little bit longer
SOURCE: One gas burner only clicks & makes spark,
5 burner Thermador Stove Top. Middle Burner that has a on , off delay feature. Will not light off I have replaces tubes, and solenoid and all is clear up to were it connects to the main inlet tube. Still no gas and won't light off has a spark also? Had 2 techs to look at it and still no luck? Help...
SOURCE: burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
