The RR of your model number stands for reconditioned, your actual model number is K5A, I believe that the side trim band says Hobart on the side, if not you may have a new trim band (Generic type) put on during the reconditioning to pretty it up. In any event in the back of the mixer is an end cover, at the top is a small Phillips head screw, remove it and lift the end cover up and slightly out, (because there are two small and fragile clips on the back that can be easily broken off, they help hold the end cover in place so up and out ) once the cover is removed you will see a black and copper plate with three chrome screws on it in an upside down triangle shape, the two top screws are for adjusting speeds from stir to 6, the lower one is for adjusting speeds from 6 to 10, Turn the screw on the top left to the left a quarter turn while the mixer is in the stir position. it should start turning. if not turn the screw on the right a quarter turn, the mixer should start, if not turn back the other way (both top screws a half turn) if it machine does not start then there is a strong possibility that it is the bottom screw, the bottom screw can and sometimes does get turned in or out due to the pressure caused by contact that it makes with the speed control switch bar attached to the side speed control switch, so let's try that one, turn it counterclockwise or clockwise (no more than one full turn) a quarter turn at a time, if it is the bottom center screw causing the problem then it should start within a full turn, try not to turn the screw in either direction more than one full turn as you can really screw up your speed settings. Don't panic I am probably making it sound more difficult than it really is, just remember that a little is a lot. I am a KA tech and every machine that I have worked on that has a low speed not working correctly it has turned out to be these 3 screws.
If your machine goes to high speed from the get go no matter where you put the speed switch, well that is another problem, but if your machine is not working on lower speeds when set to the lower speed and it does work at higher speeds when the switch is set to the higher speeds then it is the 3 adjusting screws on the speed control plate. hope this helps if not let us know
