After DVD is loaded screen says no disc- will read music cds but only few dvds are played successfully
Have a detailed answer on wiki.answers under how to fix a dvd player. My conclusion is : 1. If the cd or dvd player won't start a disc (might display 'no disc')
open the box and get good access to the laser lens (quite easy in many
models). Clean the lens with an ear-bud (q-tip) and add some alcohol (I
used after shave) on to aid the clean if there are still reading
problems. Persevere with cleaning before trying option 2.
2. If
it's selectively rejecting certain dvd's (and the problem might have
become worse with time) consider ever-so-slightly bending the fine wires
that suspend the lens over the laser, in an upward direction. Be very
careful and read all the observations above first (on Wiki).
SOURCE: Samsung DVD-R130 will not load dvds, but will play CDs
I just filed a complaint with Better Business Bureau against Samsung. Would anyone be interested in joining me in the complaint?
SOURCE: Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
SOURCE: Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
4)This
folder is the DVD/CD-ROM Drive Class Description in the registry.Look
for any of the following names in the right hand column.
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8)
Open My Computer and check to see if your CD or DVD drives
havereturned. You may also want to open Device Manager and verify that
theyellow exclamation and error code on the CD or DVD drive is gone.
