Wiper motor will not turn off
SOURCE: 2005 Nissan Murano - wiper arm
Check the nut, that holds the wiper arm on. It may be loose. Tighten nut and recheck. Let me know what you find.
SOURCE: Wiper Linkage
if you live near montreal you got yasmine auto at laval they got mostly part of qx4 but it fit for pathfinder if they dont got it usely they can tell you where
SOURCE: 1996 nissan sentra windsheild wipers not working
This is the relay switch and its located inside the dash board. the part itsefl will cost 40.00
SOURCE: 2004 Nissan Maxima wiper problem
Karen...
There might be a fuse with more than just the wipers on it. Does anything else not work? A blown fuse is most likely the cause, it might be hard to locate check owners manuel for fuse locations as they can be in several locations.
Denny
SOURCE: How do I access the windshield wiper assembly?
You have to remove the wiper arms by prying off the black platic piece over the nut. Remove the nut and the wiper arms. There should be 5 places on the black plastic piece that runs the length of the windshield. Remove 4 of them by prying them out. The one is the middle is a screw. Pull away the plastic piece and you should have access to the mechanism below. I think you need to replace the linkage if it has fallen off.
