Whirlpool Accubake RF362LXTT Electric Kitchen Range Logo
Posted on Jan 20, 2013
Cooktop light doesn't shut off - Whirlpool Accubake RF362LXTT Electric Kitchen Range
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Feb 04, 2013
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
2066
Points
9
The temperature sensor located on the that element is failing. the sensor red light reminds you that the burner area is still hot. The light should go out once the glass top has cooled,but the failing sensor won't allow it. A slight rap with your hand on glass top over that burner once cool will put the light out. It more than likely continue until the unit is replaced.
Broiler doesn't work
Do you have it on the right setting, I did that before.
Radiant cooktop made a pop noise and doesn't work
Your radiant heat element is probably blown. Call kitchenaid for information and replacement part numbers then search online for a good price.
2helpful
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
2answers
Cooktop won't ignite
-Possibly bad connect between igniter's main line to power.
-Check it out and replace. Make sure the gas line is shut off completely before work on and test.
Good luck and enjoy
Mai
Cooktop short circuits the electrical fuse when plugged in
Try removing parts or connections until the fuse does not blow.
With a gas hob, you are limited to a short in the ignition system.
As the igniter has failed try removing it. This should solve the fuse problem, if it doesn't, look for a short in the wiring.
My igniter on the cooker doesn't work, it doesn't click or make any sound
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
May 17, 2011 • Ovens
20helpful
3answers
My miele induction schott ceran is being locked, and I can not open it to cook??
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
Ignitor doesn;t work
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Feb 02, 2011 • Cooktops
1helpful
Miele gas cooktop flame shuts off after lighting. If I keep the button down longer to allow more gas to flow to the burner it will stay on.
I had similar problem.Solved by Miele tech by placing rice grain sized wad of paper towel inside knob so it sits slightly higher on the valve shaft.
2answers
Popping noise and red light
it could be a switch, element or a short somewhere else
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
