Phone won't keep charge with new battery . Charge at night and something is just not right . Set up to connect to car when on road
SOURCE: Batteries draining problem?
this problem can be caused by many factors. Use of the phone can drain battery life for example if you use the phone for browsing the web or as an mp3 player, even to make or recieve calls the battery life will not be as long as it would if just on standby. also if the battery hasn't been conditioned or is being over charged this can also lead to short battery life.To resolve the problem try conditioning th battery, basically let the charge drain completely out of the phone until the phone actually switches off, then charge the phone for 24 hours. Next time the battery goes ded only charge for the recommended charging time (this info can be found either in your phone user guide or by contacting the customer service department of your network provider).
SOURCE: Samsung t509 won't charge
would something like this work?
http://www.bayho.com/p/PCMB-DC-KE850.html
SOURCE: Charging the battery on Samsung Upstage sph-m620.
Well if it's new, then I would take it back to the store from where you bought it. It will be under warranty so, if something is wrong you should be able to get it swapped out with a working one.
SOURCE: Samsung Alias will not charge.
try with another battery. if it charge you have battery problem. if it doesnt you have motherboard problem with phone
SOURCE: Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
1. get it repaired, under warranty if possible
2. Get a new one
3.Get
an external battery charger and charge battery separate from
phone.Another battery and charger will set you back about 10 dollars on
ebay
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge problem
