Generac GP6500E - 6500 Watt Electric Start Portable Generator w/ Logo
Anonymous Posted on Jan 20, 2013
I have a Generac 6500E. The electric start turns over the engine but will not start. Pull start works fine
Anonymous
Level 3:
Genius:
  • Master 1,669 Answers
  • Posted on Jan 20, 2013
Anonymous
Master
Level 3:
Genius:
Answers
1669
Questions
Helped
427654
Points
5349
If the pull start works, but the electric start doesn't try the following. Either give the battery on the generator a full charge, and if after a full charge it doesn't start, get a new battery.
  • Anonymous Jan 20, 2013
    Thanks Leigh. I'll give it a shot but it seems the electric start turns over the engine at a decent rate so I'm assuming the battery's OK. Is there any kind of extra wiring or a spark advancer associated with the electric start verses the pull start?.
    Last idea...change the spark plug!
Tool Shed SG6500E Generator. What kind of gas cap goes on it please?
Question edited for clarity, full 'make model (what it is)'
Question moved from Cars and Trucks.
$262 for a new tank and cap!
https://generatorguru.com/6500e-6500w/
One of these looks similar
https://www.google.com/search?q=tool+shed+sg6500e+generator%2C+gas+tank+cap
1helpful
Generac XG10000E - wont crank. No sound at all. Battery is fine.
See following link
https://www.generac.com/service-support/product-support-lookup
Check fuse and connections between start switch, control board, and starter solenoid.
ENGINE CONTROLLER CIRCUIT BOARD
GENERAL:
The engine controller board is responsible for crank-
ing, startup, running and shutdown operations. The
board interconnects with other components of the DC
control system to turn them on and off at the proper
times. It is powered by fused 12 VDC power from the
1helpful
Error code 1518 on a generac generator
If you have a Generac Generator which fails to start during a power outage and gives an Error Code 1518 - RPM Sense Loss you can try and manually get the generator restarted very simply. ... The generator should wait 5 seconds and then try and auto-start up to 3 times.
https://www.justanswer.com/small-engine/bwmwi-working-generator-generac-protector-qs-38kw.html
I have a Generac 30,000 watt propane generator. The 5.7 GMC engine and the generator both work fine, but it came without an automatic transfer switch. What ATS will work with this unit?
notify generac or electrical companies [private or commercial ] for the information since fixya doesnt have any specs on your service or building
GENERAC LIGHT TOWER MODEL MLT6SMD IS BRAND NEW WITH 23 HOURS OF RUN TIME AND WIL NOT START. TURNS OVER AFTER 15 SEC DELAY, BUT DOES NOT START. FULL OF DIESEL AND OIL
hi
it looks that a wire feeding the little solenoid switch come away or damage ( this solenoid switch it turns the fuel on when the engine gets activated )
a// faulty solenoid
b// no electric supply to solenoid
1helpful
2answers
Error code - 2400...stopped-alarm- fuse problem, fuses checks good
I has this problem after performing Schedule A maintenance. Called Generac. They advise this a trip caused by removing the fuse before work to prevent engine start up, The fix is to turn unit in off position and then press ENTER key.
I have a Briggs and Stratton home stand by generator 7000 it starts in manual but wont start in auto engine just cranks but wont start
make sure gas valve is open, and run switch is ON. I'm not a fan of B&S engines. I have a Generac generator with NO problems.Pull start the unit and let run for 5 mins. Turn off. Now try the electric start.If it does not start, you have an elctical problem when using starter. Make sure battery is fully charged before starting. Hope it helps.
2answers
I have a rural king generator 6500 E It starts fine but after a few Minutes it dies?
It sounds like it is starving for fuel. You probably need to rebuild the carb.
1helpful
2answers
I Have a Rural King Generator it starts Fine but only runs a few minutes and it shuts off
Make sure the gas is fresh. Also, take off the carb bowl and look for signs of gumming. If there is gooey stuff in the bowl, then the carb needs to be cleaned.
Need a sigma 6500e assembly diagram
I just purchased a Sigma 6500E generator, there was no instruction manual with it. Did get in stalled, but couldn't find out where to connect the battery cable, also there was nothing about the engine at all. Does the battery get charged when the generator is running ?
I would hope that information is available for this unit. thank you
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
