the tv is about 4 years old, and has one componet input if im not mistaken. i'm pretty sure it isn't digital ready.the tv is about 4 years old, and has one componet input if im not mistaken. i'm pretty sure it isn't digital ready.
You can't post conmments that contain an email address.
if this set has a power relay the contacts in the relay are welded closed; unplug set for 10 seconds and plug back in; it will probably come streight on if relay is stuck. replacing relay will fix if this is the case
You may have a loose solder connection on a PC board in the color circuits. You might try jarring the set by hitting it at different places on the cabinet. NOT TOO HARD !
Like not with a hammar.
If there is a loose connection it may show up.
Also check to make the color level control hasn't gotten turned down.
Hope this helps.
Sometimes when you move a set you flex the circuit boards. If there is a poor connection it may show up--- in your case in the color circuits.
Stargazer
