Our smeg dishwasher stops in mid wash cycle and i have to start it loads of times to get a fall wash as it just freezes.
the far left 2 lights show too ?
any one know what to do or what this means ?
found the problem now for all of you who have a similar problem i gave it a damn good aquavac and poored water into the researvoir and pulled the water up through its sprinkler outlets and any other areas i could think of,, all apears to be well now ..found the problem now for all of you who have a similar problem
Same Problem for 6 months! having to run 3 half cycles to get a wash - And as it never reaches the rinse dry cycles I get wet dishes!
Problem: any programme Cycle will run for 30mins - then 4 peeps sound, machine stops with all programme lights lit. In the instruction manual it says water extract problem - but not how to fix?
What do you mean by AquaVac???
AnonymousMar 23, 2014
turns off partway through the wash cycleturns off partway through the wash cycle
You can't post conmments that contain an email address.
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty. It is not easy to replace unless you have good experience with repairing dishwashers.
You have a timer relay issue ,probable need a new board for it ,a cheap fix would be to time it and see how long it take to run full cycle and put a regulaer outlet timer on it or a alarm off your stove or what ever,save a couple of bucks
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing. Eric
this is Usually caused by a tablet sticking in the Detergent Dispenser. This will stop the Detergent Dispenser from opening at the correct time on the wash cycle.
Try turning power off, unscrewing the back panel of the machine and removing, reaching inside and giving the wheel which looks like a waterwheel (has 'fans') a couple of turns. This is the pump and sometimes small particles jam the wheel. Turn the power back on and if still in mid-cycle should resume and finish.
Water pre-heatingYour
dishwasher may pre-heat the water. If so, and if the water entering the
dishwasher is cool, the heater may take up to half an hour to heat the
water.
To avoid the wait, increase the incoming water
temperature before turning on the dishwasher. Do that by running the
kitchen sink faucet until the water runs hot. Or increase the
temperature of the hot water to the entire house at the hot water
heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
i have this problem
sorry but what do you mean aquavac?
can you give more detail on how you resovled this
thanks
Problem:
