Roper RAS8445KQ Top Load Washer Logo
Kenny Wagner Posted on Jul 17, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Agitator-How do you get it off?
My Roper RAL5144AWO Washing Machine, agitator won't spin when clothes are in. Home Depot sent me some parts(reinforcement cupling things-3 discs?) Can't figure out where they go or how to do it. They sent me no directions and I have no manual. How do you get the agitator off? Help?
  • Kenny Wagner Jul 17, 2007
    Thanks, I've got it torn down to the nut, I have to get a longer extension, any idea on size of the nut? The parts I got are "Motor Coupling". It's a black rubber piece with a hole in the middle and six hole in the outer circle and two triangular pieces of plastic with metal holes in the middle.
Anonymous
Level 2:
Sergeant:
  • Expert 274 Answers
  • Posted on Jul 17, 2007
Anonymous
Expert
Level 2:
Sergeant:
Answers
274
Questions
0
Helped
328908
Points
573
(Roper is actually made by Whirlpool) This is simpler than it sounds, just takes time and a few steps. Do you have a fabric softener dispenser that resides on top of the agitator? This dispenser simply snaps onto the top of the agitator. Some styles use a decorative cap. To remove the dispenser, simply grab it and firmly pull up. There is a cap that covers the bolt or nut that holds the agitator in place. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (the part that moves). Use a twisting or prying action to pop the cap off of the agitator. Sometimes there is a little slot where you can insert the screwdriver. Look for it first. There maybe an internal debris cap under this: Inside the agitator you will see a cap with a raised handle. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring. Removing the agitator: When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt or nut from the agitator stud. Don't use plyers, it'll just mess up the nut. With the bolt removed you should be able to remove the agitator by simply pulling up. Twist back and forth CW & CCW when lifting. Some are a 2 piece design, so pulling up will actually remove either the whole agitator assembly or only half of it. If whole assy comes up and you may need to seperate the two for your new parts. Place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator. As far as your parts go I'm not sure where they go without seeing it myself. There is a spline or ratch assembly which causes the agitator to move back and forth. They are usually made of plastic and get worn or break. This might be what you are replacing. It's not clear as to what parts they gave you. Good Luck
  • Anonymous Jul 17, 2007
    Oops ...to re-install just reverse the steps. That agitator fits ove "spines" so don't force it back on. It should drop in easily.
    Best if you can borrow a "socket set" that goes up to 1". I think it's 1/2" to 5/8" but without seeing it I'm guessing. Once the agitator is off you'll have a better idea of where the parts they gave you will go. Here a link just to show how many variations there are in parts just for Roper.
    http://www.repairclinic.com/0080.asp
    Once the agitator is off you'll see the drive mechanism. I'm hoping you don't need to pull the tub out too. That's a whole different issue.
    Let me know how it's going.
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
The agitator is not turning but i can hear the mechanism turning inside the agitator. is there a sheer pin broken? this is a roper heavy duty / large cap.( model #ral5144awo) top load washer.
AGIT DOGS ,,, go get or order whirlpool part number 80040
replace those and you should be good to go.. they are under the cap and have lil grippers on them that wear down and help rotate the agaitator assy..
5helpful
3answers
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
10helpful
2answers
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
1helpful
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
4helpful
Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
1helpful
Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
Machine won't agitate or spin.
Its possible that the agitator that turns back and forth, to clean your clothes, is warn-out. I had the same problem with mine. If your agitator has a fabric softener piece on top of it, there should be a plastic circular clip, that you have to lift up, that removes the fabric softener piece. Once you remove that, there is a plastic cap, that covers the bolt, that secures the agitator, to the drum. After you remove the cap, you will see 4 plastic hooks, that grab to the inside lining teeth, of the agitator. If the 4 hooks are worn out or the teeth are worn out, then this is your problem of why it won't spin nor agitate. I put 2 small screws, one on each side of the clips, so that the clips stayed out, against the teeth, so that at least it would work, until you can replace the agitator. I hope this works for you.
Rooper washing machine- unbalanced spin - rocking agitator
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
2answers
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Top Roper Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
