When viewing DVDs my home theater system plays them back in a very yellowish green color. I hvae looked through the instruction manual for any info for resolving this problem, but it is no help.
There should be a setting on the DVD's menu for output of picture. You should look under colour settings, to see if it has got NTSC output. You should also check your TV it might not be set to NTSC aswell. You can look in the user manual of the DVD to see if says anything about NTSC playback. If you have lost the manual you can download it for free on the Panasonic website.
If it won't playback NTSC discs, I'd guess you can get an adapter from somewhere.
Be sure that in the setup menu, you are selected for the correct output format (either component which is BLUE/RED/GREEN + audio or composit which is just YELLOW + audio. If that is correct, I would suggest a call to the BOSE technical support center.
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
I thought that might be the problem and it was, thanks.
