I have a rotator on my antenna & wanted to add stations for different positions. I had a converter box prior to the Visio & it would accept the RF channel for the digital station - ie input channel 3 & it comes up with digital 15-1, then I could manually save that to my existing list of channels. I can not do that with the TV tuner - only means seems to be to do a rescan which looses the channels stored from the scan at the previous antenna orientation. Is there a way to select a digital channel without using the scan method (I know the RF channels to input)? Is there then a way to add this new found channel to the existing stations already in memory?
SOURCE: Vizio VA26L - Tuner problem. After approx. 6
Take the set and reprogram it where one of the other sets are ok. Digital signal is not so forgiving as analog, also place one of the sets that is receiving that station in place of the not receiving one. It's possible that the signal level at the bad spot is on the border line and that model can't hold on to it. You may also check visio's web site for any software up grade to your model that you may have to down load.
SOURCE: VHF channels come in however UHF channels are not
uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
SOURCE: I have a Sharp LC-15AV7U LCD HDTV. The unit can
Checked all track in line of tuner if you have multimeter checked volteg on tuner pin as return on board.
SOURCE: Polaroid FLM4034B Everything but the
Correct if the HD is not being picked up or its not working that would be in fact you HD tuner board, should be all in one anyways on this poloroid.
Hope this confirms what your looking for, please do leave your rating once you leave, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
