I am trying to wall mount the TV. I cannot remove the stand, Is there a method to do this.
Thanks,
Roger Bird
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Usually there is four to six screws to take out. normally located on the back of the tv towards the bottom. the manual has labled which screws to take out. make sure you find the center of the stud and put your lag bolts in it. dont use sheetrock anchors or mollys. the tv will eventually fall off the wall. always use the load barring studs.
Received no instructions when purchased the tv. Want to remove the stand.
