How do i change the region code on my comuter. I just bought a DVD which said it was compatiable with all region codes however i cannot play it on this laptop. I have gone into properties - DVD region tab but cannot set my dvd region code to the new zealand region. The chages remaining are 0. Can i change to a new region? if so how please. Thankyou decoder.
Microsoft Windows XP Professional Version 2002 Service Pack 2
I have a similar problem, but more complicated. I changed my region code the other day to watch a foreign film, but was aware that i had another change left so would be able to change it back. But now I insert the region 2 disk (my home region), and WMPlayer (or the Dell Cineplayer) won't play it. It says:
1.'Your system is set to region 1. To play this DVD , set your system to region 2, 4 or 5'. - I click OK and change the region to Region 2 (UK)
2. The computer warns me that 'This is your last chance to change the region setting on your DVD. Are you sure you want to proceed?' - I click yes.
3. Then an error message pops up saying 'Unable to update region setting. Please make sure the drive contains a region 2 media and you have administration privilege'. I click OK as there is no other option.
--The problem is that I changed it before and no one else has an account on my computer so I must have administration privilege . Apparently I also have 1 change left, and I am inserting a region 2 disk. So why won't it let me change back to my real region? And how could I fix it?
Thanks
The region code in computers is limited by hardware, the player and not windows controls that.
You can circumvent hardware issues altogether with Remote Selector (www.remoteselector.com).
Just download, install and follow the instructions on the web. No more worries about what region the player is set at. Boom, it's gone and you can bypass all the other messages and warnings.
WBR09
Well you could go to start / settings / control panel / system / hardware / device manager / expand where it says CD Dvd Drives / Rightclick your drive then go to properties...... In the region tab you can change your region code. Just a note you can change the region code only 5 times. The last time you change will be locked to that region. You can also buy software known as Any DVD to set the code to 0 ...... so you dont need to change at all
Legally, the only way to resolve your issue is a new drive, the region code in the drive has been locked in the firmware and cannot be changed by normal means (You can search google for DVD region Code Cracks, but it is not recommended no legal)
Antipiracy laws mandated a limit to the number of times the Region code can be changed (5) and if you are going to be playing a lot of media from different regions, then get another drive and set it to one region (and mark the region on the drive) and use this for the other
Thanks - but it isn't that I am going to be watching more foreign films or have used up all my changes. According to my computer i still have 1 change remaining - I just don't know why it won't let me make the change. I just want to be able to do what it says I ought to be able to do - I have only changed the region once!
My problem starts 1.3 of the way down the above post. From 'Microsoft Windows XP Professional Version 2002 Service Pack2'...
Thank you, yes the problem is fixed now.
In answer to the clarification request:
The problem was that I still had one change left (I had changed it only once, so had one change left according to the computer), but Windows Media wouldn't let me go through with the change whenever I tried. This seems to be because the disk I was trying to play wasn't a region 2 only disk, but was a region 2,4 and 5 disk.
Ramesh's suggestion to try to play a region2 only disk proved successful.
Thanks for all your help though everyone.
