Question about Jacuzzi Signa 6 Whirlpool JAC-B540...
How to fix jacuzzi hot tub with fl-1 code - Jacuzzi Signa 6 Whirlpool JAC-B540...
4 Suggested Answers
SOURCE:
  • 80 Answers
SOURCE: heater pump does not turn on Jacuzzi hot tub 325
Heater operates seperate from pumps. Do the pumps come on? Pressure/flow switch turns on heater, so if the pumps work, there is an issue with the heater element, the flow switch will usually prevent the spa from running at all and there will be an error code on the control panel.
Posted on Aug 19, 2009
  • 80 Answers
SOURCE: jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Posted on Sep 28, 2009
Coastsider
  • 331 Answers
SOURCE: Jacuzzi hot tub model J-300 series with an FL-1
A flashing “FL1” display means the flow switch is
malfunctioning open, the filter cartridge is excessively
dirty or an “air lock” condition has occurred at the
circulation pump intake.
Posted on Apr 14, 2010
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Jacuzzi j355 hot tub FL1 code flashing on control panel
sounds like the recirculation pump isnt working FL1 means no Flow pump 1
Aug 24, 2014 | Jacuzzi Pool & Spa
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
Rod
US Parts Center
Mar 06, 2014 | Jacuzzi Home
My hot tub top control is flashing SPA6,and hot tub is not heating up.
Here is a link for you to resource that error code.
click that link and scroll through them until you find your error code.
Rod
US Parts Center
Aug 19, 2012 | Jacuzzi Pool & Spa
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
What does FL mean on my hot tub?? water doesnt circulate but is still sort of warm...
FL could be a code for low flow. If you have no circulation this sounds like it. If your pump runs and you have no flow you could have a problem with your pump. Or if you have the tub drained then it could be an air lock, if you open the drain valve till you get water out that should fix that. Also check to be sure the isolation valves are open under the spa. I hope this helps.
Feb 07, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Jacuzzi hot tub model J-300 series with an FL-1 code. I have shut off power at box and restarted a couple of times and the circulation pump reset. Now the reset won't happen. Both pumps still operate and I...
Jan 06, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Jacuzzi Signa 6 Whirlpool  JAC-B540... Logo
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
