It begins to spin then the outer part of the drum seems to slow, then slip off the center bottom part of the drum and it continues to spin what connects the 2 pieces
SOURCE: Avanti W797: Tub won't spin or water does not empty.
cold water inlet never stop. whenever I turn on the tap ..the water from cold water inlet will not stop ,even the mashine is full....
SOURCE: My avanti w797, suddenly stoped
There could be a couple of possibilities which are explained below :-
1. Lid
switch is not being engaged .Remove rear top cover , Phillips screws - snap clips use flat blade screw driver to pop cover .Look at rear of
lid (door) right side plastic arm part of lid snapped off replace lid, then check safety switch manually over ride switch as
a test .If machine spins change lid if switch broken as well change
both.
2. This could be a problem with pump.There is a clog some where between the connector that hooks up to the
sink and the other end of the water hose that connects to the washer.
Remove the water hose end that connects to the washer and there should
be a screen in the end. Either the washer side or the hose side of that
connection. This screen protects the water valve from debris that comes
through all water pipes and faucets. So as not to allow it to reach the
water valve.
This valve is activated by a Solenoid. So either you will find a clogged hose or it has a defective water valve or solenoid.
Let me know,once you check all the above details.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
