I HAVE TRIED SETTING THE SLEEP MODE ANDIT WONT SET TO 00 IT WILL WORKFOR A FEW MINUTES THENIT TURNS ITSELF OFF
Ok my ilive 20” sound bar ITP100B turns off only if i turn the volume up and when there is any bass when I have the volume up it turns off but if I put the volume low really low it stays on I tried the auxiliary and that is when it did that then I tried the RCA it did the same thing so what do I do how can I fix it,what do you thing is the issue I am putting a different speaker in it to see if it might be a short in one of or both of the speakers?PLEASE HELP ME!!!
I changed from using the AUX jack to the RCA inputs and its staying on. So obviously it has a prob with the AUX jack not being seen as active
I'm having the same problem. I don't think it has anything to do with the Sleep settings, you can play with them all day & the only benefit you may get is forcing it to stay on for 90 min or whatever instead of 15.
(I've tried setting to 00, obviously the first thing that comes to mind is that it's a Sleep Setting issue, but I seriously doubt this. You can't even set the Sleep Setting to 15min anyway)
Instead, I'm pretty sure that the problem exists in the sound bar not recognizing that there is an active signal & is shutting off due to what it sees as inactivity (timing out after use). I've come to this conclusion due to multiple complaints of the same problem.
Some people are reporting that it's not happening when they watch movies, others have tested & said the radio stays on as long as you like, a couple people have posted that theirs works fine & only shuts off when they turn off about 15 minutes after they shut off the audio source, which leads me to think that this is what is going on, the system thinks the audio source (TV, Bluray, etc) is off & no sound is coming through. It must have a funny way of detecting it...
I will try a few tests & if anything works I will pay the results. One person claimed there's stayed on after turning their TV all the way up... I could try this but will have to turn TV speakers off (currently I am running both TV speakers & sound bar). Anyway, I'll keep digging, must be some way to get this to work, I hope...
SOURCE: ilive 37
Turn off the sleep mode. For some reasons the geniuses ship it with a sleep setting already on. Hold the sleep button til it shows the time then press the sleep button several times until it displays 00. good luck!
If you need further help, reach me via phone at https://www.6ya.com/expert/alicia_a8df133aa44867a7
SOURCE: ilive 37
Mine does the same thing it shut off and I have to turn it back on it gets to be a pain can anyone help us on how to fix it.
Thanks
John
