Question about Canon Pixma MP450 All-In-One InkJet Printer
Error code 6000
I tried to print something on my printer today...it said there was a paper jam... I throughly checked it out and there was no paper jam. It is now giving me error code 6000 and the Alarm light flashes. Any ideas on how to fix? I've tried turning off and back on as well as unplugging.
  • 20 more comments
  • alan0511 Nov 20, 2007
    error 6000 canon pixma mp 450
  • Anonymous Nov 24, 2007
    error code 6000
  • Carol Diane Dec 01, 2007
  • superally Dec 08, 2007
    there is no paper jam, yet that is the error reported. It prevent me from priniting, or even using any of the utilities such as cleaning.
  • Anonymous Feb 24, 2008
    WHAT DOES ERROR 6000 MEAN
  • Anonymous Mar 19, 2008
    Getting ERROR code 6000 on Canon Pixma MP450. How do you fix ?
  • lizzzytish Apr 07, 2008
     Canon MP500  6000 error message, plus there is a grinding noise when the printer is turned on . I opened the back to check for paper jam- no paper in there. It doesn't help to turn the printer off an on. I thought maybe something (a pencil?) could have rolled into the manual paper feed, but can't find anything.
    What to do?
  • Tulips_25 Apr 17, 2008
    Hi! I'm having the same error 6000 with a iP1300, do you think it works the same?
    Tks!
  • Anonymous Apr 20, 2008
    i get the same problem with me canon pixma ip1600...i still cant solve it..who can help me??frustrating with it...
  • Anonymous May 28, 2008
    I have the same problem here with a Canon MP450 - Code 6000 - I know it has something to do with the paper feeder. Have turned off printer, unplugged everyting, have looked for paper that might be stuck, nothing. Whatelse can I try. Thank you.
  • Anonymous Aug 03, 2008
    i have same problem whith my pixma mp150. what happened ?
  • ash_halloran Sep 30, 2008
    I have the same problem ever since i changed my ink cartridges, which are in place fine, everytime i go to print somthing itll pull the paper down about half an inch or so n make the noise that its printing and then when it goes to spit the paper out i get the error message that its jammend but its not because the paper never went through the printer. Ive checked the printer inside out and followed the instrustions people listed below and nothing has worked for me. :S Someone please help.
  • Anonymous Dec 10, 2008
    Same problem.  Nothing wrong--checked ink, paper tray, no jam.  Going crazy!
  • diljewel Jan 31, 2009
    I am getting Error Code 6000 in my Cannon iP1880 Printer.
    The Yellow light flashes...
  • rishikaa Feb 11, 2009
    yea.. i am having d same problem.. plzz provide me wid a solution
  • waybill52 Feb 14, 2009
    same problem as jenvaldez,paper jam error code,with no paper jam
  • martidehn Mar 01, 2009
    I have a Canon PIXMA MX 700 series and am having the same problem. First paper jam message, no paper jam. Reference the Quick Start Guide which said to unplug the printer for a few minutes and plug back in. This DID NOT correct the problem. Any help out there?
  • Anonymous Mar 18, 2009
    Thank you for all the solution advice! I was "sure" there was no jam, until I read all the above similar problems. Got looking more closely and found some yarn wrapped around the roller. Got it out, and it is working great again.
  • Anonymous Apr 22, 2009
    I had the same problem but there was no paper jammed, i even tried shaking thr printer which has worked for jams in the past but i have never had error code 6000 before. I used solution #6 but turned the wheel on the LEFT not right. It now works fine! thankyou!
  • Anonymous Apr 23, 2009
    Pixma 300 for 1 month, now flashing alarm light with "6000" error. Have looked in all access areas for a jam and see nothing. I noticed also, the ink catridge carriage does not roll to the left anymore when i open the body of the printer. Frustrating!
  • chaaos May 11, 2010
    i have shaken my printer, checked every nook and cranny, even tried cleaning it out with some solution ... nothing has worked. I have a canon MP470, and it wont work at all anymore ... any other suggestions???
  • Jesse Mason Aug 22, 2014
    same here---owned 3 weeks, used twice...permanent paper jam or "no paper". useless POS
    New Friend:
Sounds like driver related problem to me, try re install your driver by CD, or just download this Driver Update Software for XP Vista 7 8, and update the driver. Have a nice day
Prime
Posted on Jan 07, 2015
    New Friend:
I have been driving myself crazy with this same problem MP470 Error 6000 to no avail cleaned the machine to the extreme...no paper inside. Followed solution #9 but still in error. Used these reset instructions and now feel like the smartest person on earth. With the power off, press the reset button (red) and hold while pressing the green power button. Release the red reset but continue to hold the green power button. While still holding the green power button, press the red reset button twice and then release both green and red together. Now press the red reset 4times. Power off and you should clear the blinking orange. Hope this helps someone else. Now I need to go clean this ink off my fingers!!!
Posted on Dec 15, 2009
  • Susanne Gervay
    Susanne Gervay Sep 17, 2014
    You are a genius as there were NO instructions anywhere - thankyou and double thankyou - you are a supermom!
I had the same problem - error 6000 on my Canon MP810.
I read how everybody checked the back and turned it upside down and shook it, so I did it, too. Then I reopened the front and saw a little piece of something, so I carefully tugged and out pulled a piece of cloth! Problem solved!
Posted on May 20, 2009
Had same problem Error code 6000 on PIXMA MP450 to solve this issue I lift the lid and rolled the wheel on the right hand side (plastic with black rubber drive belt) connected to stainless steel shaft. This wheel should be able to roll in both directions for 10 full turns with no obsruction. If the wheel stops there is something jamming the drive motor giving error 6000. I fixed by rolling the wheel back and forth and finally the obstruction was free. Printer was left fully function hope this helps.
Posted on Jan 11, 2009
Had the same error message with Pixma MP560 (tried to coulor copy)
Turned off and on - no success
Turned off opned the printer
Turned on
Copied black&white
-> everythiong works fine
Posted on Jan 18, 2010
After the third separate occasion of trying to fix the problem, and cursing my Canon Pixma 450 for inventing a paper jam, I realized ... there WAS a paper jam!
A tiny piece of paper had lodged itself behind a piece of plastic and was so hidden I didn't even notice it till I took the printer off the shelf and inspected it from multiple angles under full light.
After about 10 minutes or so with a tweezer, I was able to pull the piece out and I'm back in business.
Be sure to lift up the lid of the printer and get a good look in there. Good luck!
Posted on Aug 15, 2008
Same problem here with MP800. After reading through sugestions on this support side I open printer up and found a tiny piece of rubber inside paper feeding mechanism. Printer working fine again now and saved me for a trip to the junk yard ;-)
Thanks a lot for this net-page
Posted on Aug 30, 2008
The reason for the mistake is a loose belt that no longer connects the motor with the paper feeder.
Three steps solve this:
- Remove the left side cover of the printer
- To do this for the MP 520 you need to remove the little gray front left cover first, then the four screws at the back, and then the left side cover (this is complicated as you need to undo 7 craws on the left hand side all marked by little arrows and spread out all over the printer)
- just put the belt on, it's easy to see
Have fun,
Markus
Posted on Jun 01, 2009
  • tnt4him50 Oct 10, 2010
    Solution #6 worked for me with a mp990. I did not have to open anything up. Instead I looked inside to the left where I saw two white gears. Just by chance I noticed what appeared like black type writer ribbon around the large white gear. I was actually saturated ink on remnants of paper. I used a pencil tip to flick it out of the gears. Some of it disintegrated and would not come out. I then turned the gears counter clock wise until I could not see any more of the black paper remnants. I turned it on and passed a paper through but then read error 6000 again. I repeated turning the gear again and turned it on and it works now. These printers must be very sensitive to any type of paper jams. The machine was not lying.
Same problem with my MP210. I did a live chat with tech support to no avail. Before calling a repair person, I checked here and read about all the little things that can get jammed inside. I got my flashlight and aimed it in every little corner. Voila! I discovered the corner of a candy wrapper sticking out from the feed and pulled it out with a pair of tweezers. Now it's good as new. I suggest a thorough going over with a flashlight into every crevice before calling for repairs. Another suggestion: Keep anything and everthing away from your printer tray and feeder opening, including candy wrappers!
Posted on Oct 18, 2008
Thanks to everyone who posted here! I was having the same issue with my MP600 and reading these posts provoked me to sit down on the floor with my printer for a full examination. The solution to my problem turned out to be a non-inflated balloon jamed under the paper feed holders inside the machine. No "paper jam", but rather a "balloon jam".
Posted on Mar 31, 2010
    some of those wrappers, etc. MUST come form the factory. Do you now remember dropping a balloon in there?
    New Friend:
No paper jam warning just code 6000. Turned upside down, shook, dusted, vacuumed, begged...nothing, took thick cardboard (the kind that comes with photo paper to be exact) and forced it back and forth through printer in both back and front where paper usually runs. Cleared right up! HURRAY!!!
Posted on Feb 12, 2012
    New Friend:
Error 6000. I kept looking for pieces of paper jammed somewhere. Didn't see any. Loaded a piece of paper from the rear and turned on the printer. The paper will feed through, normally. However, I noted that the paper stopped at a roller visible from the front and as I lift of the cover. This roller is just below and behind the ink cartridges. I noticed that the roller was not tuning. So I used my finger to reverse the roller by pushing on its gears (it would not go forward). The next time I turned on the unit, the roller moved the same distance I turned it back to the original position. That was my clue. So, I reversed the roller much more, and to my surprise, a rubber band came into sight. Once the rubber band was removed, the printer started working. It seems most of us have the same story,that we are looking for an object. Some of them are not visible. Look for parts that are not moving that should be moving, as well as all the previous hints.
Posted on Nov 07, 2011
  • Paul Alexander
    Paul Alexander Nov 07, 2011
    Actually, this was for an MP 560. Same basic problem/solution.
    Master:
  • Canon Master
  • 262 Answers
Give a try to cannon tech support here on the new number (877-690-9305)
Posted on Jan 26, 2018
    New Friend:
Hal;anhvjhcb yucu
Posted on Jan 25, 2012
Same problem, but couldn't see any paper anywhere. Turned it upside down and gave it a gentle shake, problem cleared!
Posted on Sep 02, 2008
I had same trouble with pixma MP110. Did everything but no luck. Noticed the paper feed tray was off centre...turned it all upside down and a drawing pin fell out. it was jammed behind thepaper feed and unit itself. All works well now. So, check something has not dropped into the paper area!!!
Posted on May 16, 2008
I've experinced the error 6000 with my Pixma ip 5000. (the lamp kept blinking and a message on my monitor told me to turn the printer off and then back on, if that didn't help I would have to contact a repairman. The hell I thougt, I would'nt pay for reparing a 3 year old printer, I'll fix it. I checked the paper tray, nothing that could cause an error, then I tried unplugging it from the USB cable, nothing....then I discovered a lock on the backside of my printer, I opened it and there the error was...PAPERJAM. I carefully pulled out the paper tried not to rip it. Voil? printer WORKS FINE!!!
Posted on Aug 11, 2007
    New Friend:
I've add the "Error 6000" problem several times before, and turning it off and on never did anything. Very frustrating. But then I read the posts here.
Even though I didn't remember any paper jamming, I pulled out the paper tray, looked, and sure enough! There were two small pieces of crumpled paper underneath, in the back, near where the paper goes up into the printer. I just lifted the printer up grabbed the pieces (which weren't even jammed, they were just lying there), it started working immediately!
Posted on Dec 21, 2011
    New Friend:
I had the same problem on a Canon MP540 while making a photocopy. It turned out that the front drawer was overloaded.
1. I switched the printer off,
2. removed the drawer,
3. removed some sheets from it,
4. switch the printer on
5. relaunched the photocopy
6. as I got the "paper out" message i put the drawer back in its usual place and it worked!
Posted on Dec 21, 2010
Hi just push back were is the paper tray some time when printer take paper and the paper push to take its dont go back.you just push back and it will work your printer.
Posted on Sep 10, 2012
    New Friend:
As far as I know I couldn't find any paper jammed in it or anything. I took out the tray, took the paper out, couldn't see anything and put it back in. When I turned on my computer again it thought about copying it for 10 minutes and then worked perfectly. After that it took the normal amount of time to copy.
Posted on Jul 27, 2010
2 Suggested Answers
SOURCE:
  • 34 Answers
SOURCE: Error code 6000
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Posted on Apr 27, 2009
Error code 6000
Error 6000 is a line feed error, it means the platen roller isn't advancing properly. It usually means something has fallen in from the back where the paper goes and is stopping the rollers from turning.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
Jun 14, 2011 | Canon PIXMA mini260 InkJet Photo Printer
Printer error has occurred 6000
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer then back on again. If the problem persists, see the manual." Is displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy large documents such as books, make sure that you secure the clear space in front of the tray before printing / copying. When the error message above is displayed and if you find something is in front of the tray, remove it. Then, turn OFF the printer and back ON again and the printer will be ready for printing.
If you still have the trouble, contact the repair service.
2. Open the cover.
4. Close the cover.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 14, 2011 | Computers & Internet
Printer Error message : Printer Error has occurred. 6000
2. Open the cover.
4. Close the cover.
Dec 21, 2010 | Canon Office Equipment & Supplies
Canon pixma mx340 4-in-1 wireless printer thinks it's jammed when it's not. say "error 6000". Assistance is greatly appreciated. thank you
error 6000 is a paper jam, which means there is something in the flag that senses whether or not there is paper in the path. Look very carefully in the area just before the paper comes out before the printing area. You will likely find a small piece of paper stuck, or a small object. Often a small inspection mirror helps.
Oct 31, 2010 | Canon PIXMA MX340 Wireless Office...
Getting code 6000
Error code [6000] or light blinking 3 times.
1. Smearing or scratches on the LF encoder. Please clean the LF encoder.
2. Foreign material or paper debris in the LF drive. Please remove any foreign materials if encounter.
3. Check cable connection.
4. Replace LF encoder or Logic Board or Paper Feed Motor or Paper Feed Roller Unit
May 27, 2010 | Canon PIXMA MP620 All-In-One InkJet...
I keep getting error 6000 when I am trying to print how do I rectify this
Hi there
I think THE 6000 is the same problem error as the ERROR 6A00
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 19, 2010 | Canon BubbleJet i560 InkJet Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
What is error 6000
I the paper is jammed. Purge unit is jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Jun 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6000
Apr 27, 2009 | Office Equipment & Supplies
Canon Pixma MP450 All-In-One InkJet Printer Logo
64,367 people viewed this question
Clive
Clive
old marine
old marine
Ekse
