Question about Sony Ericsson K610i Cellular Phone
Phone won't charge
I got my phone wet and now it doesn't charge. Does anyone now how to manually charge a phone battery, like a circuit or something?
  • lukumay Feb 26, 2008
    MY PHONE HASN'T NETWORK ALL THE TIME WHAT CAN I DO? (C) nmp 2600 nokia
  • Anonymous Apr 02, 2008
    IHAVE ANOKIA 1100 BUT IT HAS NO CHARGING OUTPUT IHAVE MEASURED THAT OUTPUT WHICH IS NORMALLY 3.5V .WHAT IS THE PROBLEM
    New Friend:
1280 CHARGING IC SOLUTION
Posted on Sep 17, 2012
    Problem Solver:
  • 8 Answers
When the phone gets wet i gave taken the phone apart and used a hair dryer to dry it out.
you could have shorted the terminals on the microchip board.
Posted on Mar 06, 2008
    Sniper:
  • 60 Answers
Hi, The Li-ion battery cahrging circuitary is some what complex. For most chargers, the charging procedure is divided into three main phases: ? Pre-charging phase ? Constant-current-charging phase ? Constant-voltage-charging phase In the Pre-charging phase, it utilizes low charging current to protect the battery. However,in most recharging situations, the charged batteries still have some voltage remaining, so the charger does not need to apply this action, and just passes it on to the next charging phase. The constant current and voltage charging phases are the main charging phase for recharging the batteries, where most of the charging energy is transformed into the battery. The maximum charging current for a battery depends on the battery?s rated capacity. For example, one battery rated 700 mAh usually can be charged at 350 mAh to 400mA, for faster charging effort. When the charged battery is Li-Ion, in the last charging procedure, the microcontroller normally maintains regular charging voltage while monitoring charging current to determine when the charging procedure should be completed. When the battery is fully charged, most of the electrical energy is converted to thermal energy, which can result in high battery temperature. In this case, the temperature monitoring function will be added for the solution. But since most Li-Ion batteries on the market also have an over-charging protection function, the temperature detect function is rarely used. So it is better to get your phone charging circuitary checked at a local store rather than to make a charger,coz both may cost you almost same. all the best my friend. regards sreejith
Posted on Jul 16, 2007
    Problem Solver:
  • 9 Answers
Desk top charger could work if you think the battery is still ok...the white spot next to the gold contacts on the battery indicate if the battery is dry. The safest solution is to try another battery to see if the phone is still ok
Posted on Jul 25, 2007
SOURCE:
Phone won't come on
my name is Larry and i have the exact same phone. If ur lg isnt turning on and wont charge it could be couple things . either the charging port on ur phone needs replaced and or ur charger has gone bad i would take it to a cell phone repair shop close to you.
Mar 25, 2013 | Net10 LG Optimus Logic Cell Phone
My galaxy ace got wet and now won't charge what can I do
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 02, 2012 | Cell Phones
Jitterbug phone got wet
you can put the phone and battery seperatly in a bag of rice and leave it overnight. if this doesn't work then its too far gone
Jun 03, 2012 | Samsung Jet S8000 Cell Phone
My device won't charge
This situation sometimes occurs when the batteries get overcharged. Use the phone for a day and then attempt to charge. If it still won't charge, remove the battery for about a minute. Then re-install the battery and attempt to charge. If that doesn't clear the problem, you may need to get a new battery.
Mar 03, 2012 | Motorola Mobility T505 Handsfree...
I was on the phone with my BB Torch, then the battery ran out, i got back the next morning, tried to put it on charge, nothing happen, no red light, no indicator , nothing, tried the charge for few ghours...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. If the red light doesn't come on, connect the charger and put the battery inside. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 09, 2011 | RIM BlackBerry Torch Cell Phone
My nokia e63 fell in water.... what is the solution????
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days then reassemblethe phone. Hopefully it will work properly but if does not work then it isfaulty and you need a new cell phone.
Jun 25, 2011 | Nokia E63 Cell Phone
My Samsung phone has no power, won't accept a
The battery is most likely at fault, though if a different battery still doesn't work, there's probably something else to blame.
May 20, 2011 | Samsung Cell Phones
Battery won't charge
Please get it serviced through Service Center.Battery may be dead .Battery gets short circuited when wet .
Oct 28, 2017 | Samsung Eternity Cell Phone
Phone went through washing machine, has dried out but wouldnt charge
Ferg,
What a pity. Such a lovely phone gone down the drain, almost.
If it stayed in water for that long, at least 45 minutes, it must short circuited all its components. Even if one IC goes Nokia scraps the phone.And in your case you cant say how many.
Are you still hoping for a miracle. Well, recharge the battery. It will take a long time to show "charging" as the battery must have drained completely. After that follow the procedure in the link below.
Got Your phone Wet? - Save It Now.
And I too hope there is a miracle.
Dec 16, 2009 | Nokia 5800 XpressMusic Smartphone
Sony Ericsson K610i Cellular Phone Logo
2,560 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
