We have just brought our set home from being repaired - the picture would constantly fade to black after staying on for a few minutes - the repair was relatively cheap and only replacement was a new circuit board, but recently the picture has gotten worse. It ranges from the picture constantly distorting vertically by bowing at the corners and other times simply compressing the image vertically all together. Also if the screen were to brighten, or there happens to be a white background the image would just warp randomly and then return to normal. Sometimes you won't notice any problem with the picture, but there is always some issue happening 80 % of the time. It happens on every input and there will always be a very low hum coming from the back of the set when this occurs. If it is a connect issue with the previous problem we had, then that can be covered under the warranty of the repair, although it is a heavy set and a pain to transport. Thanks for any help.
I highly doubt the circuit board was replaced, you had a simple 2 minute repair I'm sorry to say. They only re soldered the CRT board or the fly back connections, very common on this TV set. You now have a power supply issue, or a vertical drive or output problem. If you just brought the set home, I would contact the repair shop and see what they have to say and ask them the part number for the board they replaced. bet they say they forgot or don't remember. Good Luck
Sorry I forgot, he told us that the original plan was to replace the circuit board, but when we got it back he said he just replaced five capacitors and charged us less. Even if it is covered under the repair warranty, I am wondering if this can become a reoccurring issue, if this is the case, it won't be worth the effort of hauling it back to the shop.
Thanks for the input
