Question about Nostalgia Electrics CCP-600 Vintage Collection 59" Old Fashioned Movie Time Popcorn Cart
The On/Off Buttons Have Broken Off
The two red on/off button to turn the machine on and off as well as the button to turn the light on and off broke off. We have had this machine for a little over two years now, and we use it about 3-5 times a week. It would be great if we could get some new buttons for the machine.
Beater overload on one side
turn the power off and hit the reset buttons about the size of a quarter hole on the back or front panels. turn back on and it should clear if not then you will need to have the beater motor or contactor replaced.
Oct 08, 2014 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Broken Gear
This might be helpful.
http://home.hiwaay.net/~karthur/Freezer/White%20Mountain%20Motor%20Repair.html
Jan 02, 2014 | White Mountain F69206X 6 Quart Ice Cream...
Ice maker don't make ice, the three red lights just keep on blink
Hi, The water tray on the machine is probably broken where it connects to the motor. I have the same problem, and am trying to reach Greenway to see if I can get a replacement part. this seems to be a common problem with this ice maker.
Oct 05, 2009 | Polar PIM15W Ice Cream Maker
Broken part
Available replacement parts can be found here:
http://www.directpartsandproducts.com/other-ic200-c-1_1486_1691.html
If the part required is not listed try the posted telephone number: 1-800-738-0245.
Sorry it has taken so long for someone to respond.
Apr 24, 2009 | Black & Decker IC200 Arctic Twister 2.11...
Ice cream maker "agitator" broke
I searched in vain to find a standalone part for the Rival 8401-M, but here are some leads:
You can call Rival and see if they still have the part in stock, although it is doubtful since they don't even have support for the machine on their website anymore.
I found several never-opened and used Rival 8401-M's in working condition on eBay and other places on the web, ranging in price from $16.00 - $35.00. For electronic products that are more than 4 years old, I reccomend buying used, because a unit that is NIB (New-In-Box) may be dead as a doornail (The analogy I use is this: if you have a Ferrari, no matter how well-built, and you let it sit unused for 7 years - when you go to start up that Ferrari after 7 years, it's not going to work because the parts have degraded, etc over that time period). Here is alink to an auction for a working, used Rival 8401-M
If your blade is broken, I did not find replacement blades anywhere on the web. If it is, in fact, the agitator that is broken, I have two leads:
Here is a web site that will show you what an agitator looks like (it is the tiny part that they are pointing to in red):
http://www.twinsupply.com/proddetail.asp?prod=176-1055&partner=herb
Ace Hardware, at one point, stocked the Rival 8401-M - if you take it in to them, you can see if they have an agitator that would work (if it is, in fact, the agitator, and not the blade that is broken).
My final reccomendation is tongue-in-cheek: Buy a new Cuisinart ice-cream maker instead - a simple one like the ICE-20 can be had for $20-$40 brand new.
-Tha Mp3 Doctor
Mar 17, 2009 | Rival 8401-M 4 Quart Ice Cream Maker
Taylor 751 sp dead
Sound like you might have a loose wire or ribbon cable,might even be a loose wire on switch.Be sure to turn breaker off to machine and unplug it before you check them. Also check the motor reset.
Jan 24, 2009 | Taylor 632-27 Ice Cream Maker
Need to replace broken part on Simac Pastamatic machine
Where can I get parts/disks for a Simac 700 pasta machine?
Jan 05, 2009 | Simac Ice Cream Makers
Emerson IM90 Portale Ice Maker
My friend bought this item last week at Target for the $99 sale price. The reviews were all horrible about the red light (add water) indicator going on after the first or several first ice cube runs and never going out. About 40 out of 60 reviewers had this problem. We experienced it right after the first run when the ice cube full light went on. We emptied it and the add water red light was on. I looked all over the web for a solution and only found one that suggested tilting the unit backwards for 45 degrees and that would magically reset the light. It did not after several angles, light taps and basic shaking. Since there was no alternative and everyone who returned it also got the exact same problem with the new replaced model - we decided to open it up and investigate.
The electronics diagram is on the back of the machine and tell you where the water indicator is. We took it out (an inch long black tube along the water pump and backflow valve) and dried it completely. The cycle still had the red light. We submerged it completely in water and the red light still went on saying that the unit needs water. We determined that this is the bad part and the water indicator is faulty. We cut it out and joined the two wires. IT ALL WORKS NOW FLAWLESSLY. You only have to shut the unit off when you leave since it will ocntinue to run if out of water. If you're looking for a quick mechanical fix and have a unit that works when you need it and you are around - this isthe fix.
Aug 23, 2008 | Ice Cream Makers
Gear drive broken
Try Ebay....... you'll get the part at ur doorstep......
Good luck!!!!!
dont forget to rate this post.......
Aug 21, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
Taylor 770 soft serve
754-27 Taylor soft serve machine Beater motor not running - compressor not engaging - Power to beater relay but not out of relay.
May 18, 2008 | Ice Cream Makers
Nostalgia Electrics CCP-600 Vintage Collection 59" Old Fashioned Movie Time Popcorn Cart Logo
181 people viewed this question
Top Nostalgia Electrics Ice Cream Makers Experts
Tom Chichester
Bill Boyd
Are you a Nostalgia Electrics Ice Cream Maker Expert? Answer questions, earn points and help others
