Apple G5 17 in (A1058) Mac Desktop Logo
tommy Posted on Jan 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vertical stripes display shows vertical stripes
Jason Johnson
Level 3:
President:
  • Apple Master 1,619 Answers
  • Posted on Oct 17, 2013
Jason Johnson
Apple Master
Level 3:
President:
Answers
1619
Questions
0
Helped
441012
Points
3913
Bad screen or video card.
1helpful
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
My TV is showing only vertical stripes. Audio is ok
Hi Arquimedes,
It appears to be a Tcon board issue. Tcon boards are repairable at times. Please contact some good TV tech.
I have a 1cm verticle stripe on my Dell Studio 1737 ?
Your lcd screen is going bad. You can verify this by plugging an external monitor to your laptop. if the external monitor shows without the vertical stripe it means the video card is good but your old screen is bad. If the external monitor shows the stripe then it means the video card is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
After turning screen ix initially blank although backlight is on. Gradually vertical stripes appear of varying width and colour. Eventually lines change to horizontal bars howing sections of the correct...
Your display is faulty. Check out ebay for a replacement. Changing the display is straight forward. If you get your display we can instruct you on replacing it.
Hope that helps.
1helpful
Display shows vertical multicolor stripes at startup
The display has failed and needs to be replaced.
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
2-inch picture stripe in middle of screen.
deight, your set is going into total vertical collapse, either the vertical IC is failing or some support component to the vertical circuit is failing, should not be an expensive repair, hope this helps, BMW Rider
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
