It will be the brush holder in the motor has broken.......Ive just had my 4th brush holder break up, The design of them is rubbish!
Im planning on making a hole on the motor casing to accept proper brushes, Ive taken them apart and replaced the broken brush with one out of another motor and bought a faulty one for the brush holder.
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
Bothights on indicates a problem with the battery. You cam try cleanibg the battery terminal with a Q-tip moistened with alcohol. Allow it to dry completly before tryin to recharge. If that doesn't work the battery may be defective or broken. If it was dropped that could cause the damage.
Solution is two fold. Will try the freeze and re charge approach today and do this a few times. The long term soluiton is to purchase two Lithium batteries and a duel chemical charger. Expensive solution but seems it will work.
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
You are ok with what you got. The cordless saws take a lot of power to cut wood so it drains the battery fast. I have the ridged setup and my battery on a full charge only gets 4 cuts on a 2x4 befor it is dead. The saws will not give you any worning becauase the teath of the blade will get stuck in the wood so it just will not slow down like the drill will. I hope this helps with your ?
