Question about Kenmore 43052 Front Load Washer
Indesit wil103 makes LOUD banging noise on spin cycle
My washing mashine makes a really loud thudding noise on the spin cycle. Its 3 years old. Was thinkin its the belt, is it easy to replace yourself. It doesnt make any screechin or scraping noises, so i was hoping it wasnt the bearings!
  • lisaiow71 Jan 28, 2009
    thanx will have a look, did check the belt and that seemed fine.
  • Anonymous Mar 19, 2014
    Started washing then stopped half way through still as water in and lights flashing tried cancel it an turned it off at the mains but won't. Work is making a noise not aloud noise not a bang
The two dampers that fix to the outer drum casing have plastic bushes that can fall out. Check the floor under the machine, They are easy to replace just click in place.
Posted on Mar 23, 2009
  • swddcleaning Jul 29, 2011
    I just cleaned my drain pump and my machine is torn apart. Could you please tell me what a damper is and where it may be located so I can check for the bushings. I sweep and mop under my machine, I am sure I tossed them if they were there.
  • Oil can Arry Jul 29, 2011
    Sorry thats an old expression , dampers are what people now call shock absorbers.They look like the rear shocks on a car. Two tubes one of which is smaller in diameter and slides in the other. The bushings are white plastic and are located either end. Go to google images type in shock absorber and you will see what they look like.
    Sniper:
  • 100 Answers
May be the weights that balance the drum vave come loose. there are large bolts that attach them to the drum. do not overtighten them as you risk breaking the posts off.
have a look under the lid. if the weights aren't loose check under the machine for the suspension may be disengaged.
indesit technicians will use a torque wrench to ensure the correct tightness of weight bolts.
Posted on Jan 28, 2009
SOURCE:
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
Why does Miele w2515 makes loud banging noise when it is about to spin?
See if you can level out the unit. Sound like the case is responding to un-even pressures.
May 23, 2014 | Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
FWT449GFS2 making loud banging noises during final spin cycle
lxr6232eqo making loud banging noises during final spin cycle
Aug 31, 2009 | Frigidaire Washing Machines
Not spinning when on Regular wash mode.
sounds like the agitator is damaged and needs to be replaced
Jun 21, 2009 | Washing Machines
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore 43052 Front Load Washer Logo
1,774 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
