Hi....F3
Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven
sensor and oven control. Replace oven temperature sensor (RTD) if wiring is
ok.
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1Safety flip flopReplace Electronic Range Control/Clock (ERC) F2 - E0Shorted keypadReplace Electronic Range Control/Clock (ERC) F3 - E0Oven temperature sensor or oven temperature sensor fuse openedReplace oven temperature sensor or fuseF3 - E1Oven temperature sensor shortedReplace oven temperature sensor F3 - E2Oven too hotReplace oven temperature sensor F3 - E3Clean temp too hot Replace oven temperature sensorF5 - E0 F5 - E1 and E2 Door latch problemCheck door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of yourmodel # 0-5 that will determine which control it takes. Once you havethat # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
F1 - E0 EEPROM communication error F1 - E1 EEPROM checksum error F1 - E2 UL A/D error F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match stored value F2 - E0 Shorted touch pad F2 - E1 Keypad cable connection error F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models) F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models) F3 - E2 Oven temperature is too high (Cook mode) F3 - E3 Oven temperature is too high (Clean mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models) F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models) F3 - E6 Drawer sensor open F3 - E7 Warming drawer sensor shorted F4 - E1 Meat probe malfunction - shorted F5 - E0 Door Switch F5 - E1 Self clean latch will not lock F5 - E2 Latch during CLEAN error F5 - E5 Self clean temperature not reached within 45 minutes. F5 - E6 Door is open, but latch is locked F5 - E7 Self clean latch will not unlock F6 - E0 Return line not connected F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure F1 ERC Board failure F2 Oven temperature is too high F3 Oven temperature sensor open F4 Oven temperature sensor shorted F5 ERC Board failure F7 Function key stuck on ERC F8 ERC Board failure F9 Oven door lock failure
If you get an error code, try first resetting the code: 1. Disconnect power for about two minutes. 2. Connect back power. 3. If code re-appears, test and eventually replace faulty part.
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper oven, if double oven) F3 - E2 Oven temperature is too high (Cook mode)
Hello,4 Digit Failure
Code
F0 - E0
Analog to
Digital Failure
Disconnect
F1 - E1
Safety flip
flop
Replace Electronic
Range Control/Clock(ERC)
F2 - E0
Shorted keypad
Replace Electronic
F3 - E0
Oven temperature
Replace oven
F3 - E1
Oven temperature
sensor shorted
Replace oven
temperature sensor
F3 - E2
Oven too hot
Replace oven
temperature sensor
F3 - E3
Clean temp
too hot
Replace oven
temperature sensor
F5 - E0 F5
- E1 and E2
Check door/latch
switch
Replace component
2 Digit Failure
Code
F0 or F1 or
F5
Failed transistor
Replace Electronic
F2 - E0
Oven temp
too high
1. Test
operation of door lock on self-clean models 2. Test relay contact operation 3. High resistance in oven temperature sensor
F3
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure Disconnect for one minute - if error comes back, replace control board F1 - Shorted control keypad Replace keypad F3 - Oven temperature sensor open Replace oven temperature probe F2 - Oven temperature sensor shorted Replace oven temperature probe F3 - Oven too hot Replace oven temperature probe F3 - Clean temperature too hot Replace oven probe F5 - Door latch switch fault Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop) Replace control board F2 - E0 - Shorted control keypad Replace keypad F3 - E0 - Oven temperature probe open Replace temperature probe F3 - E1 - Oven temperature probe shorted Replace temperature probe F3 - E2 - Oven temp too high Replace temperature probe F3 - E3 - Clean temp too hot Replace temp. probe F5 - E0 - Check door latch F5 - E1 - Check door latch Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error Replace ERC F1 E1 - EEPROM checksum error Replace ERC F1 E2:7 - UL A/D errors Replace ERC F1 E4:2 - Model ID error Reinsert keytail. F1 E6:0 - Latch signal mismatch error Replace ERC F2 E0:4 - Shorted key error Replace keypad assembly F2 E1:3 Keytail unplugged reinsert the keytail F3 E0:5 Top oven sensor open Test and replace top probe. F3 E1:6 Top oven shorted Test and replace temp probe F3 E2:9 Bake range over temperature Test and replace temp probe F3 E3:8 Clean range over temperature Test and replace temp probe. F3 E4:10 Bottom oven sensor open Test and replace temp probe F3 E:15 Bottom oven sensor shorted Test and replace temp probe F5 E0:14 Door switch errot Test and eventually replace door lock switch F5 E1:16 Door latch not operating Test and eventually replace door latch F8 E0:17 Refrigeration error Test the cooling module. PF Power failure - Does not indicate a fault. PF occurs when power is disconnected.
WHIRLPOOL Models SF3, 30'' and 24"
F2 - Oven temperature above specifications Check 8-pin connector from temp. probe to Electronic Oven Control F3 - Open oven temperature probe failure Check wiring, replace oven probe if necessary F4 - Shorted oven temperature sensor failure Check wiring harness, replace oven temperature probe if necessary F5 - Push button stuck or faulty Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 - Electronic control logic error (timing) Replace Electronic Range Control (ERC) F7 - Electronic control logic error (lock motor) Replace ERC. F8 - Electronic control logic error Replace ERC.
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
