Question about Jacuzzi Signa 6 Whirlpool JAC-B540...
Water not coming out properly from one of the jets
I sat in my jakuzzi for 30 minutes and it went off for 7 seconds and came bach on its happened to me twice can some body help me. and the other problem one of the jets the water does not come out properly
  • 10,865 Answers
Hi there. FIrst of all be sure the water lever is above all of the jets for it to work properly. REgarding the jet where the water does not come out properly i am not sure what that means. BUT, the jet is adjustable so turn it and see if that fixes the problem. good luck.
Posted on Jan 26, 2009
SOURCE:
I have had battery and alternator checked, both are good. Battery was dead, jumped car, started and ran fine. Drove 30 minutes, shut off and sat for 2 hours. Started fine again, just went to gas station...
Most likely you have a bad battery. The second option is that you have a faulty wiring and there is a constant load that takes a lot of power, but it does not make a short circuit. Check the electrical relays, maybe it's in them.
Sep 06, 2017 | Cars & Trucks
I have a lasko ceramic heater. It was working fine one minute then I turned it off and when it got chilly again, I tried turning it on but it wouldn't even beep, let alone turn on.
Wow... I hate REFERRING ANYONE to SEARS ($$$$)...
but they pop up very prominently for Lasko parts... and their support library is pretty good...
So... (top link at the bottom)
1-800-252-1698
M-F 6:30 a.m. - 10:30 p.m. CT
Sat 7:00 a.m. - 9:30 p.m. CT
Sun 7:30 a.m. - 9:30 p.m. CT
Always get three estimates...
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
repairclinic.com
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
easyapplianceparts.com
Find Your Appliance Parts
Feb 13, 2016 | Lasko Heating & Cooling
Starts stalls
contaminated or water in the fuel is most likely the culprit here.
drain the tank and carb (small screw at bottom of carb float bowl)
Add fresh fuel from a CLEAN fuel source. Best to completely drain your fuel can and fill it up with fresh fuel. That way if the fuel can is the culprit you eliminated doing this twice.
What happened was fuel sits on top of water, this is why the bike would still idle. The idle circuit in the carb pulls fuel from a higher point than the main jet. This is also why when you hit the throttle it would just die, it was sucking most like something other than fuel.
Apr 02, 2014 | kawasaki KX 450 F Motorcycles
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
How do you clean the jets in a whirlpool tub? Is there any product to put in water and run jets to clean them?
Put white vinegar in the water and run it through your tub. Fill the tub to it's maximum running capacity, which is normally just above the jets, and pour a gallon of vinegar in the water with it. Let it run with the vinegar for about 20 minutes, then turn it off and let the vinegar sit in the jets for about 30 minutes. Then start up the jets again for about another 10 minutes and drain. Then run plan water through the jets for about 15 minutes, drain and that should do it. I would recommend doing this at least once every 2 months depending on your water type and how often you use the tub.
Feb 13, 2013 | Home
Check engine light for 2006 Chrysler Town & Country came on when driving. Then after we parked it for the day, it wouldn't start back up. It is making a clicking noise. The day before this happened...
There are several cases: Fuel system is dirty or your pump not working properly, Computer box connector lose, spark plug worn out, Tune up and high voltage not sufficient.
Sep 24, 2011 | 2006 Chrysler Town & Country
I have an old AquaWhirl tub that was out of commission for several months because of a breaker problem. I replaced the breaker but when I turn on tub I get 5 seconds of normal whirl followed by a big burst...
Due to your tub setting for a long period of time, you have a simple air lock in the jet hoses.
Find the pump - locate the jet farthest from the pump and using a funnel slowly pour water in that jet until water starts coming out of the other jets.
Turn you tub on it should work fine. If this does not solve your problem you may have to loosen the top hose at the pump and allow the air to escape while being replaced by the water you are pouring in
Mar 05, 2010 | Home
I have a 1984 500CX that sat all winter and the gas got real stale- smelled bad; so I drained it and put in fresh gas. It started right up but when I went for a test ride it has almost no power and can...
No, most likely you have a blocked jet. If you have the expertise, strip the carbs and clean them out, if not, taking the carbs off and sending them to a carb rebuild company is less than $100 each, plus they will renew all the old parts (seals, jets, etc.) and your bike will run like new!
Jun 27, 2009 | 1982 Honda CX 500 B
Whirlpool icemaker not working properly
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Jacuzzi Signa 6 Whirlpool  JAC-B540... Logo
233 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
