Hi I have a fridge freezer that is around 2 years old, the compressor runs but the appliance doesnt get colder (fridge or freezer ) I dont think we have accidently de gased it , I was going to change the thermostat but there seems little point when the compressor is clearly running ( +you can hear fluid in the system ) Id be grateful for any clues.. (Ps it is an upright indesit model not and Engel as described above.. Thankyou.
How to fix my indesit light inside the fridge reply asap
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
SOURCE: Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
My fridge freezer is 12 years old. The fridge part seems warm no motor going. when I turn the appliance off and on again the motor starts for a period. Does the fridge and freezer work off the same motor if so because there is still ice in the freezer it may be just taking its time to defrost.
I have an Indesit GSE160 fridge which is 18 months old, and it is not getting cold. Have you resolved your problem?
Kirkcaldy gal
