I flipped the washer upside down to check on the belt, it was too loose, all parts spin freely however I could not find a way to tighten the belt. Can you help? Thanks
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components. Enter your model number into the PartDetective on the Find & Order Parts page to see all the parts available for the unit.
We have a magic chef washer and we learned that the belt is not adjustable, (we also thought it was too loose.) We removed the lid switch and cleaned it up, tested it with a simple ohmeter, replaced it, and it's been working fine since. Hope this helps.
Hello there: i will have to do this in two posts ok so here is the first part
Many
washers use a small, relatively inexpensive
motor coupling. It's plastic and rubber and is mounted to the shaft of
the motor on one side, and to the transmission on the other. Over time,
the coupler wears out and fails. you need to completely
replace it.BeltsMany
washing machines have one or two belts. If a belt is broken or badly
worn, you need to replace it with a genuine belt from the manufacturer.
(Some washing machine belts are designed with special characteristics
not found in automotive belts.)Clutch may use a clutch for agitating the
clothes. As the clutch wears out, If the clutch is worn, you need to replace it.
There are many
possibilities for this problem, but the most common and regular problem seen is
as follows:-- There is a lid switch in
the washer. The washing machine will not start spinning till the lid is closed.
In some cases it has been seen that lid is closed still the washer does
not spin. in this cases the lid switch has to be checked. if the lid
switch is faulty then the closed lid will not be detected by the washing machine,
and it will not start spin cycle. But if the lid switch is ok checked,
then other possibility can be fault in the motor coupler. Many a times the
motor coupler is broken .The motor coupler is plastic/rubber kind of material
fitted on the shaft of the motor .Check properly if the motor coupler seems
cracked, worn out loose or broken then it needs to be replaced to solve the issue.
But if motor coupler is checked ok then other possibility for this problem is
the spinning belt. If the belt is worn out or loose or
cracked/broken then it needs to replace. Only for GE washers. In GE
model washers, there is a clutch used for proper spin speed. If the clutch
wears out, it has to be replaced to. But if clutch/belt seems ok. then other
possibility is driver motor itself .check if the motor has power if not then
the motor is got internally burnt .in this case the drive motor needs to be replaced.
but if drive motor is functioning properly then other possibility to be checked
for this fault is the transmission shifterand pulley. If the transmission shifter becomes defective, the unit may
drain the water but not spin. Replacing the shifter is bit time consuming and
tough job. you will require proper tools to deal with this problem. But if the transmission
shifter is properly working then other basic possibility to check is the spin
bearing/basket drive. The part may be rusted ot got worn out completely. So the
inner tub is not spinning freely inside the outer tub. If this is the case then
you will hear a loud squiring/chirping sound during the spin cycle. So the
bearing fault will be easily identified. Before replacing the spin bearing
check if the bearings are got dried up or they are worn/rusted. If dried then
apply bit greasy material on the bearings and check out. But if still the noise
it needs replacement. But if the bearings are rusted/worn out then it needs replacement.
That is confirmed. This will help.Thanks.
It doesn't spinIf your washer won't spin, check these:It doesn't pump or spinIt pumps, but doesn't spinIt spins only with the lid closedIt doesn't pump or spinIf it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spinIf your washer pumps out the water but doesn't spin, check these:The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician. need parts? try Repairclinic.com
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin
where do i find the belt on my magic chef washer?
washer wobbles during the spin cycle even when the clothes is evenly sorted
