Samsung SGH-i717 Galaxy Note HD LTE 16GB Rogers Unlocked Black Logo
A
Anonymous Posted on Jan 18, 2013
Imei null/baseband unknown - Samsung SGH-i717 Galaxy Note HD LTE 16GB Rogers Unlocked Black
Samsung gt 1900 no ime baseband problem
Hi Ronaldo
Try this..
  • Open up the dialer and enter - *#06# to check your IMEI number, if you see "IMEI Null or 000000 ", you need to reconfigure the settings to fix the no signal or not registered on network problem on your Android phone.
  • In the dialer, type- *#197328640# or *#*#197328640#*#*
  • You will be prompted into the Command mode, provided On the screen, Select on Common, normally option 6
  • Now Select (FTM) Option 1. FTM (Field Test Mode) is for debugging and testing, if the option is on, you will have to turn this OFF.
  • As soon as you turn this off, your NULL or altered IMEI number will be restored
  • (Important) Without leaving the Command screen, press the Menu key, the button that's found left of the Home button.
  • Select Key input and enter option 2 which will turn your FTM OFF
  • Wait for a minute. Remove your battery and SIM card for two minutes, place your battery in your phone back but not the SIM card. Turn on the device then.
  • When the phone is booted, enter the command mode again dial - *#197328640#
  • Select the Debug Screen, normally option 1
  • After that, choice phone control, option eight
  • Click on nas control, option 3
  • Afterwards, click "RRC (HSDPA), option 5
  • To Fix not registered on network or Null IMEI #, click RRC revision, option 2.
  • Choose the released of your phone, here we will choose option 5 (HSDPA only)
  • The final step to fix Null IMEI # is to turn off your phone and insert your Sim card or else reboot your phone and then insert the SIM card to dial *#06# to see if the IMEI number is restored.
How do I change imei# on galaxy s4 that is blacklisted?
Try this website: http://forum.gsmhosting.com/vbb/f777/galaxy-s4-gt-i9500-repair-imei-null-null-1685562/
How to fix baseband unknown and no imei on my sony xperia acro s
Re-flashing your phone firmware is the only possible solution.
http://www.xperiablog.net/forum/resources/categories/xperia-acro-s.12/
How to unlock a samsung galaxy s2 net work with imei number null
You have managed to corrupt your EFS folder where your IMEI is stored.
Usual reason is that you have installed a non network firmware on a network locked phone.
Reinstall the network firmware to resolve IMEI NULL issue.
Once the issue is resolved, Get the IMEI number by typing *#06# on your mobile phone and get the IMEI number. Then visit
OnlineGSMunlock.Com to get the unlock code for your Samsung Galaxy S2 at affordable cost. with easy unlocking guide. Good luck.
How to restory factory settings for Samsung Galaxy Apollo GT-I5800?
you don't have any other option than submitting it in the service center for a software reflash..
Nov 06, 2013 • Cell Phones
6helpful
I have a facebook problem where the webpage doesnt open . It says error on page.
Proposed solution: uninstall Google Chrome Frame
I discovered the pb yesterday, trying to connect to Facebook on my XP SP3 Win32 desktop that runs fine, but on which I rarely connect to Facebook, so that I don't know for how long the problem has been here (days, weeks, but no more)
I struggled in various forums to find hints others than "use Chrome or Firefox" etc...
I finally found the solution hidden in:
http://blog.crosbydrive.com/?p=310
After uninstalling Google Chrome Frame, I just had to quit IE and launch it again.
Many thanks to "Lexington Computer Repair Blog " and Sue W (who hold the solution from a Facebook forum)
Sir my 3110c mob blocked what ido to clear this problem
im sorry sir ,the only thing we can do in this problem in the dct4 (3100 ,7210,3530 ,6610 etc) problem is changing IMEI and its already unblocked..but because of the new security of NOKIA on this what we called BB5, baseband 5 phone 3110c ,n70 .3500v etc ,even if we change the IMEI ,your phone is in phone restricted or maybe contact service status...so sad to say ,no solution in your phone sir..thanks
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
