we are having the same issue. sometimes I simply turn off the machine and restart without adding any soap. it seems to like that. but it's frustrating to not be able to do a whole load.
washer stops during regular cycle with f33 code. i have to turn power off to unlock door, then restart. I can't seem to find anything wrong with the machine. I cleaned the filter and checked the water hoses...washer stops during regular cycle with f33 code. i have to turn power off to unlock door, then restart. I can't seem to find anything wrong with the machine. I cleaned the filter and checked the water hoses...
You can't post conmments that contain an email address.
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit). Please see the following image provided for instructions.
The F33 error means that the washer control unit didn't get the expected response from the drain pump drive during a self-test (before starting the washer cycle). This is usually a wiring issue. Unplug the washer and drain out any water in the unit. Remove the clothing and pull the washer out so that you can reach the access panel. Take a look at the wiring between the drain pump and the CCU (control unit) DP2 connector. Make sure that all of the wiring harnesses are connected. Look for any broken wires or ones that are detached from the wiring harness. With an multimeter, check for continuity in these wires. If there are any broken wires, replace the wiring (Main Harness).
If the wiring is okay, check if the drain pump filter is clogged with a foreign object. Disassemble the drain pump and check if the impeller is intact and on its shaft. Replace the pump if the impeller is damaged. Reconnect the power to the washer and check if the error recurs.
I hope this helps. If you add a comment with the model number, I may be able to provide more information on the parts.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
CLICK HERE
CLICK HERE
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
5d
possible causes
* If too much detergent was used
-Run the unit thrugh a RING/SPIN cycle.
-Run a NORMAL cycle with out adding detergent.
PROCEDURE
* This should clear the unit of execess detergent.
1.- Check the draing hose and male sre it is not plugged or ****.
2 Unplug washer or disconnect power.
3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU).
4.- Check/clean drain pump filter of foreign objects.
5-Plug in washer or reconect power.
6.- Check draing pump.
7.- Check the pressure switch.
8.- Verify CCU operation bu running a Diagnostic Test or any cycle.
F33
MUST be fix by a technition Service ONLY am sorry about this inconvenient.
"Was this helpful?"
