I can run the espresso part of the machine, but the steamer won't produce steam.
I have the same problem! any fixes? ideas?
If you don't run the steamer after taking it out of the milk, the milk dries in the tube and clogs it up. For now, try taking a fine wire and poking in the hole. Then soak the steam tube in a glass of hot water to soften the blockage. Run the steam thru the tube until you get a good flow and then be sure to clean the steamer tube every time. I usually put a washcloth under the tube to catch the steam.
screw broke off
