Microsoft Xbox 360 Console Logo
Posted on Jan 25, 2009
Audio but no picture
The audio comes through but the picture does not.
Anonymous
Level 1:
Scholar:
  • Contributor 35 Answers
  • Posted on Mar 07, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
35
Questions
0
Helped
7121
Points
38
Audio but No Video/Picture Problem can be fixed with the help of This DIY Video Guide, I would suggest you to give it a try as it also provide Money Back Guarantee.
Note: If you are facing this problem either you can send your Xbox to Microsoft for repair, if yon can wait for 2-3 weeks then it is good otherwise you can fix the problem yourself within an hour with the help of above Video Guide.
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Jan 25, 2009
Anonymous
Contributor
Level 1:
Answers
34
Questions
0
Helped
10711
Points
90
Try checking to make sure your cables are plugged in correctly, or try setting it up on a different tv to see if it works. the cables could be faulty.
Try changing the input channel, you may have it on the wrong input channel.
Let me know if this helps.
I have audio, but no video, what's up? last night I was watching, and the picture went out, I truned off the TV, then restarted it...the picture came back. Today I tryed to turn it on and no picture, just...
s the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
The picture in my tv doesn't come out but he audio
It is a flyback issue and this would need to be replaced around $95 bucks for this model depending where you live.
Hope this helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
No picture on dvd but picture on tv only sound comes out on dvd
Could you try to set your channel to 2,3, or 5 when viewing video from dvd. Or try search which channel will the video and audio will sync in tune. I think this is an old tv.
Hope this one helps.
GE television
My GE 32 inch won't come on, when you turn it on you can hear click two to three times then it comes off.
I have another 32 inch GE TV that has no picture except white/gray light on the picture tube, but there is sound
No Picture but Audio is present
suspect graphics bourd may be a dry joint if it comes and goes
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
