Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood Logo
Posted on Jan 25, 2009
Tankless water heater pilot light will not stay on
I have a Bosch Aquastar AQ 125 BNG tankless hot water heater. The pilot light recently went out. After lighting the pilot light, per the instructions, upon moving the botton to the ''on'' position the gas comes on as if there was a demand for hot water. Upon trying the hot water in the bath, the water was extremely hot. When tried in the kitchen the water would no longer heat. Returning to the heating unit, it was found that the pilot was again off. I assume that the unit over heated and the gas was automatically shut off. When relighting the pilot a second time, the same result occured. My question is why, when the button is moved to the on position, the gas comes on or is this normal?
  • Anonymous Apr 12, 2009
    I believe the pilot thermocouple is bad -
    I have similar problem - instead of small pilot light there is a large flame. water heater responds to water demand but the "pilot flame' is far too large.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 10, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2963
Points
Please someone help....i have the 125bng..it will not stay lit...i have changed the thermocoupler and the gas valve...spending alot of money but no result..
Anonymous
Level 1:
  • Posted on Apr 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2963
Points
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Bosch aq 125 bng
sounds like pressure relief valve is stuck closed free of or replace
The pilot light went out on my aqua star 125 BNG tankless water heater. I lit the pilot and the burner started and now the burner won't go out it when I turn the water off Serious business anybody got...
Before calling service technician, copy following links for troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I have a Bosch AquaStar AQ-125-BNG tankless water heater, and for some reason when it is heating the water, it seems to get exremely hot and the heat is radiated back into the cold water supply line and...
Tankless should never be installed with plastic pipe, PVC or CPVC etc.
Before calling service technician, open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Water is only getting warm with aquastar 125 bng model. It just started getting warm and not hot. What could be the problem?
Insufficient gas presure. Check gas presure exiting regulator exrternal of water heater. If presure is at 3.7-inches water column gas valve is defective.
I have a Bosch 125 BNG gas tankless water heater. Pilot light will not light but spark is there. Solution and where do I get parts assuming needed.
Check and be sure gas knob is in the pilot lighting position and pushed in. Try to manually light with a match. Make sure gas **** is in the on position. Posible air in the gas line. Bled off air. gas valve or regulator has failed..
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
2answers
Bosch 125 Tankless Water Heater - Water not hot enough
sounds like your mixing valve or tempering valve not unit.Somewhere there is a unit that prevents scalding temperatures- I expect this is your issue find and adjust this first- there are directions on it when you find it.
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
