Mitsubishi WD-73736 Television Logo
Posted on Jan 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
VOLUME WITH NO PICTURE FOR 60 SEC, TV SHUTS OFF,WD-73736
THE RED LIGHT CAME ON ON THE 3 DAY OLD TV. I UNPLUGGED, AND RE-POWERED THE TV. NOW WHEN TV IS TURNED ON, VOLUME AND NO PICTURE FOR 60 SECONDS. THEN TV SHUTS OFF. NONE OF THE FRONT LIGHTS STAY LIT.
  • Anonymous Mar 25, 2009
    Check the LAMP red light, the lamp may have burned out - or may have been faulty to begin with. You should contact the seller and have them replace it...after only 3 days, im sorry but that is just plain wrong - who did you get this TV from?
Anonymous
Level 3:
Genius:
  • Master 1,066 Answers
  • Posted on Mar 27, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1066
Questions
0
Helped
497149
Points
3071
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Bulb is only 2 mo. old. i have sound but no picture. red light is on. tv shuts itself off
step 1. Try pressing reset button. step 2 if step 1 does not work. Remove front cover and lamp door press, defeat the safety switch with a screw to hold the lamp door switch in and check to see if the lamp turns on. If it turns on for up to 10 sec then turns off replace thermal fuse.
Mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
I have a 4 month old Model WD-73736 tv that is nonresponsive
i'd take it back!  it's obviously defective.  TV's are supposed to last longer than 4 months!
Mitsubitshi wd 52725
Good Day;
From you said you should call a Factory Authorized Service Center, toooo many problems with TV for non-tech person.
Good Luck, big IRISH.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
