Kitchenaid KEMC378K5504
SOURCE: need to remove kitchenaid microwave
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
This
is usually caused by either a bad door switch, a loose door switch
mount (which are pretty simple problems to fix) or occasionally a
problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch
or mount trouble can be caused by slamming the door or by opening the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab can be hard to see, since it is under the
bottom edge of the switch.
One test that sometimes helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount or
door alignment issue.
If you or someone you know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There
may also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally
made) that demonstrates how it's done.
model number here.
We're
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
SOURCE: my Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
