Phone was a Chirstmas present and the instruction book got lost...I can figure everyting on the phone out except how to retrive my phone mail....Thanks
Here is your manual http://www.vtechphones.com/docMgt/public/art/314073/i6777_manual.pdf
Hope this helps
Also the phone is a VTEC i6777
Voice mail is through your phone company,so you would need to contact them for directs on how to answer your voice mail
Answering system operation
Answering system setup
Activate the answering system
The answering system must be turned on to answer and record messages. If the answering system is turned off, the telephone base ANS ON/OFF light will be off.
• To turn the answering system on or off, press ANS ON/OFF.
Set the clock
Before playing each message, the answering system announces the day and time the message was received. You should set the day and time before using the answering system, so messages are dated correctly. To set the clock:
• Press CLOCK, and the system will announce the current clock setting. The system will then announce "To set the CLOCK, press CLOCK."
• Press CLOCK again and the system will announce the year.
• Press /SKIP or /REPEAT until the system announces the correct year, then press CLOCK. The system will announce the hour.
• Press /SKIP or /REPEAT, until the system announces the correct hour, then press CLOCK. The system will announce the minute.
• Press /SKIP or /REPEAT until the system announces the correct minutes, then press CLOCK. The system will announce the day.
• Press /SKIP or /REPEAT until the system announces the correct day, then press CLOCK. The system will announce the new clock setting and return to idle mode
The answering system uses voice prompts to guide you through the set up of the answering system. Press /PLAY/STOP anytime to save and exit the SETUP menu.
Set number of rings
This feature allows you to select the number of rings before the answering system answers. You can choose from two, four or six rings or toll saver. With toll saver active, the answering system answers after two rings when there are new messages, and after four rings when there are no new messages. To set the number of rings:
• Press SETUP in idle mode, and the system announces the number of rings setting.
• Press /SKIP or /REPEAT until the system announces the desired setting, then press SETUP to save the setting and go to the next setting or press /PLAY/STOP to save and return to idle mode.
Set base ringer
This feature allows you to select from three telephone base ringer volume levels: high, low or off. To set the base ringer:
• Press SETUP in idle mode until the system announces the base ringer setting.
• Press /SKIP or /REPEAT until the system announces the desired base ringer volume level, then press SETUP to save the setting and go to the next setting or press /PLAY/STOP to save and return to idle mode
Set remote access code
A two-digit security code is required to access the answering system from any touch tone telephone. The factory default code is 19. To set the remote access code:
• Press SETUP in idle mode until the system announces the remote access code setting.
• Press /SKIP or /REPEAT to change the remote access code by one, or press and hold /SKIP to change by increments of 10. ������Press SETUP to save the setting and go to the next setting or press
Set message alert tone
This feature programs the system to beep every 10 seconds to alert you of new messages. The beeping will stop when all new messages have been reviewed. To set the message alert tone:
• Press SETUP in idle mode until the system announces the message alert tone setting.
• Press /SKIP or /REPEAT to toggle between on or off, then press SETUP to save the setting and go to the next setting or press /PLAY/STOP to save and return to idle mode
Outgoing announcement
The outgoing announcement is the message callers hear when calls are answered by the answering system.
The telephone is preset with a greeting that answers calls with "Hello, please leave a message after the tone." You can use this factory announcement, or replace it with your own outgoing announcement. While in the ANNC menu, press ANNC again anytime to exit.
Record your announcement
• While in idle mode, press ANNC and the system will announce "Announcement, press PLAY or press RECORD."
• Press RECORD to record, and the system announces "Record after the tone, press STOP when you are done."
• After the tone, speak towards the microphone at the bottom front of the telephone base from about nine inches away.
• Press /PLAY/STOP when finished.
• The answering system will automatically playback the newly recorded announcement. Press /PLAY/STOP to stop the playback anytime.
Play your announcement
• Press /PLAY/STOP to play, press /PLAY/STOP again to stop the playback.
Delete your announcement
• Press DELETE to delete, and the system will announce "Announcement deleted."
Advanced operation Answering system operation
Message playback
• Press /PLAY/STOP to listen to messages. Press /PLAY/STOP to stop playback.
• If you have new messages waiting, you will hear only the new message (oldest first).
If there are no new messages, the system will play back all messages (oldest first).
• When playback begins, the total number of messages and the day and time it was received will be announced.
• If the system has less than five minutes of recording time left, the remaining time will be announced.
• If F is flashing in the message window, memory is full. You will have to delete some messages before new ones can be received.
• Only old messages can be deleted. Messages can only be deleted after they are played.
New message indication
• The message display counter will flash when there are new answering system messages.
• If the new message alert tone is turned on, the telephone base will beep every ten seconds
when there are un-reviewed messages.
Options during playback
• Press / VOLUME to adjust the speaker volume.
• Press /SKIP to skip to the next message.
• Press /REPEAT to repeat the message currently playing. Press twice to listen to the previous message.
• Press DELETE to delete the current message. The system will advance to the next message.
Delete all messages
• When in idle mode, press and hold DELETE to delete all old messages.
• The system will announce "All old messages deleted."
Memos are your own recorded messages used as a reminder for yourself or other household members who use the same answering system. They are saved, played back and deleted the same way as incoming messages.
Record a memo
• While in idle mode, press RECORD. The system announces "Record after the tone, press STOP when you are done." After the tone, speak towards the microphone at the bottom front of the telephone base from about nine inches away.
• Press /PLAY/STOP when you finished recording.
Memo playback
• While in idle mode, press /PLAY/STOP.
• See the Options during playback on page 31 for other options
• Memo less than one second will not be recorded.
• "Memory is full." will be announced if you press RECORD when the memory is full.
• Your memo can be up to four minutes in length.
Advanced operation
Remote access
You can access many features of your answering system remotely from any touch tone telephone. A two-digit security code is required to access the system and the factory default code is 19; see page 29 to change it. To connect remotely:
• Dial your telephone number from any touch tone telephone.
• When the system answers and announces the greeting, enter the two-digit security code.
• After hearing a double beep, enter one of the remote commands in the following table.
• Hang up or press 8 to end the call.
• If no key is pressed within 10 seconds of entering remote access, any new messages will be played automatically.
• Once the new messages have been played, the system will announce the help menu options. If no key is pressed within 20 seconds, the remote access call is automatically disconnected. �
Remote access commands:
Hang up
Saves all messages
Plays all messages
Plays new messages only
*5
Plays help menu
5
To stop
*7
Records the outgoing announcement
8
Hang up the call
0
Turns answering system on or off
Message window displays
The message counter usually displays the total number of memos and incoming messages. See the list below for explanations of other displays in this counter.
0 No messages.
1-98 Total number of old message(s) recorded.
0-98 (flashing) Total number of new message(s) recorded in idle mode.
99 & F (alternating) Memory is full with total number of messages recorded.
1-99 (counting) Elapsed time while recording memo or announcement.
99 (flashing) Recording time exceeds 99 seconds.
1-99 (flashing) Current message number during new message playback.
1-99 Current message number during old message playback.
1-8 Current volume level while adjusting.
10-99 Current remote access code while setting.
ON (or) OF Current answering system status (on or off).
02, 04, 06, tS Current number of rings while setting.
-- System is answering a call, or being set the time and date, or being accessed remotely.
-- (flashing) System is being programmed or initialized.
Http://www.vtechphones.com/docMgt/public/art/314073/i6777_manual.pdf
According to the information you have provided this is your manual... look at that and restate the issue you are having ... it sounds like you are trying to remotely access the answering machine... is that correct ?
Robert
Voicemail
If you subscribe to voicemail service and you have a new voicemail message, the VOICEMAIL indicator on the telephone base will flash and the handset will display NEW VOICE MAIL . Please contact your local telephone company for more information about voicemail service
hear is the manual
VTech #6777 Instructions
Voicemail
If you subscribe to voicemail service and you have a new voicemail message, the VOICEMAIL indicator on the telephone base will flash and the handset will display NEW VOICE MAIL . Please contact your local telephone company for more information about voicemail service.
CLICK HERE FOR DIRECT LINK TO MANUAL
Hope this helps, please leave positive feedback if it does. Thank you for stopping by Fixya, and sorry your problem has not been solved yet.
If you like to download user manual:
download from>>
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=260
Thanks
HI,
I will let you know if there is an user manual available for your model vtech 5.8i
Please click on the below link to view the manual for your phone(vtech vt9162)
http://www.vtechphones.com/docMgt/public...
If you need the manual for any other vtech models please click on the below link and choose the model:
http://www.vtechphones.com/vtechui/suppo...
Can you please let me know the make and model no. once again?
ok..Here is the manual for your model.Please go through it and your problem will be solved.Please click on the below link to view the manual:
Below is the list of manual :)
http://www.vtechphones.com/vtechui/support/manualList.cfm
Thanks.
Do u need procedure to retrieve phone msgs or code? or BOTH?
 U want to retrieve existing to retrieve existing msgs or delete msgs? Voice or Sms?
How to check voicemail is totally dependent on your phone service provider.For example, I use Vonage and I dial *123 to get into my mailbox. Your best bet is to check the website of your phone service provider or call them - there should be a contact # on your bill.................
However,
push and hold down 1 untill it says call voicemail it should go straight there
Thnx.
OK....I just paid $10 to your customer service experts for a solution to my problem.....sadly my phone has no ID on it other that 5.8 and your system doesn't understand that....I paid you $10 for some kind of a solution and I didn't get one....not a good deal in my mind - Don Osterhout.
Again....I don't know how to retrieve my phone messages from my phone with I believe to be a model #6777. No help from you guys so far!
i don't KNOW how to answer messages.
