Dryers Logo
Randy Posted on Jan 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won"t heat up - Kenmore Dryers
Mark Smith
Level 2:
Scholar:
  • Expert 197 Answers
  • Posted on Jan 18, 2013
Mark Smith
Expert
Level 2:
Scholar:
Answers
197
Questions
Helped
41921
Points
440
Check the Circuit Breaker. It is a double Breaker Switch. one side is for the heat one for the motor. If that is good then it's possibly the Heating Element or one of the two heat sensors.
Electric blanket won't heat
Take the help of your mattress pad company or look into instruction manual. Do not operate it unless you are familiar with it. You should call the customer care to know how to operate.
Jack from Coriumdirect Mattress pads
Whirlpool WGD6200 won't start
When you say it won't start, do you mean it won't heat up or do you mean it won't spin?
Nov 07, 2012 • Dryers
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Cook top won't work and oven won't heat
check the plug it sounds like the plug is not secure only getting one leg of current push in firmly
8helpful
2answers
Won't heat up
If it won't heat it will be either the heating element or the thermostat or the control board.
Heating element won't shut down
Here is a tip that I wrote about why an electricdryer will not stop heating sometimes.
ElectricDryer won't stop heating
heatman101
We have an Amana Easy Touch Control 500, the pilot is on but oven won't heat up. We also can't self-clean because the door won't lock or sometimes it locks and won't open. I suspect the...
Most likely the door for your kitchen range has a sensor that is not allowing it to heat up because it detects that the door is not closed.
I would suggest you consult help from a certified technician by the manufacturer of your Kitchen range that way they would also be able to check other possible faults on your kitchen range and replacement parts would be 100% compatible.
You can also check the services that these guys offer:
http://www.stoverepairnearyou.com/ml2/?v=1640662349&u=08E0B192DFA88BAA0210818080F80718DDA9032090DEAEEC8F8CA8CFC401
Hope this helps!
4helpful
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Dryer won t heat 100 74732400 model
dryer element. Common problem easy repair.
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 • Dryers
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
