I need access codes for universal remotes. 1128,1127,1141 do not work
SOURCE: setting presets on KLH R3100
No, not so easy, this isn't like your average car radio, unfortunately. This was driving me nuts, too, but I finally found a manual. Hopefully you have a remote, since that is needed.
Once you are on the station you want to save, press MEMORY on the remote. MEMORY will blink on the receiver's display. While MEMORY is flashing, press the button(s) on the remote for the number you want to save the station under.
Neil
SOURCE: When i tunr my KLH R3100 it gives me an error
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up. You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it. If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good. If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech. Check for loose speaker connections as a root cause for intermittent shutdown.
