Acer TravelMate 3260-4874 Notebook Logo
Posted on Jan 25, 2009
Battery status LED blinkings amber
Acer TravelMate 3260 can't power. The battery status LED blinks amber (orange) for while and goes off. Tried powering using Ac outlet with battery removed. Also tried with battery alone without Ac power. All the same, this symptom persists.
Andrew - Ugand (Africa)
Robert
Level 1:
  • Contributor 31 Answers
  • Posted on Jan 25, 2009
 Robert
Contributor
Level 1:
Answers
31
Questions
0
Helped
14480
Points
73
Try removing the power cable and battery, while these are removed press and hold the power button on the laptop for 30 seconds. this is called a hard reset, what it does is drains any residual power in the laptop. if this does not work, that means there is an issue with the motherboard. to have it sent in would cost about $398, give or take.
Won't turn on but amber stand by light is lit.......
FULL 'make model (what it is)' in all questions first 3 words.
How to fix a computer that won't turn on and has a blinking ...
Quora https://www.quora.com > How-can-I-fix-a-computer-that...
Dec 25, 2018 - A blinking orange light on a computer typically indicates that there is an issue with the power supply or motherboard. Here are a few troubleshooting steps you ...
7 answers · 17 votes: I need help my desktop computer shows orange light when opening up
Why can't my desktop power on? The orange light is ...
Mar 18, 2021
Why won't my laptop turn on even though the orange ...
Mar 30, 2023
Why is my check engine light on in the on position ...
Feb 8, 2020
Why do traffic lights in some countries (like the UK ...
Feb 25, 2017
More results from www.quora.com
Blinking amber power light - Won't turn on.
Dell https://www.dell.com > desktops-general-locked-topics
Apr 5, 2013 - If the power light is blinking green - The computer is in standby mode. Press a key on the keyboard or move the mouse to resume normal ...
6 answers · 0 votes: Hi, Welcome to the community First thing you can try is to reseat all devices inside the tower. ...
Computer won't turn on, solid orange (amber) light
Sep 27, 2013 - Disconnect any external peripherals (flash drives, printers, external hard drives) from the computer including the power supply. · Press and hold ...
2 answers · Top answer: Hi BC Taylor, Please follow the below shared instructions to identify the point of failure. ...
LEDs
IBM https://www.ibm.com > docs > SSYSP8_5.3.0 > r_coss...
Amber if the system is in standby. Green if the system has full power. Module Fault LED, Amber indicates a fault in a PSU, cooling module or SBB I/O module ...
How do you remove the solid Amber light showing o - Q&A
Best Buy https://www.bestbuy.com > site > questions > question
Jan 13, 2021 - Settings > System > LED Indicator > Voice detection status When you toggle on/off, it will either turn on the amber LED indicator or off. I ...
Lenovo z570 not powering on
Measure the voltage at the AC Adapter plug, and see if it is within 5-10% of the rated voltage. If the voltage is not correct, then the battery will most likely not be charging, and the system will drain the battery and die in the middle of what it was doing...booting in your case.
You can tell how much voltage is remaining in your battery and if it is charging by checking the blinking of the battery status light.
Download the Hardware Maintenance Manual here:
http://download.lenovo.com/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/Z370&Z470&Z570/Lenovo%20Z370Z470Z570%20Hardware%20Maintenance%20Manual%20V1.0.pdf
and go to page 30 and look at item 7 under battery status for blinking light meaning.
1. Blinking amber: (500ms off/1s on)
The remaining power of the battery is less than 5% of
its capacity.
2. Blinking amber: (100ms off/3.2s on)
The battery is being charged with the remaining
power between 5% and 20% of its capacity.
3. Amber: The computer is operating on battery power with the
remaining power between 5% and 20% of its
capacity
With the AC Adapter plugged in, and giving the correct voltage, If you are getting 1. Blinking Amber (light on for 1 sec, off for 1/2 second), then the battery is not being charged. Could be AC Adapter, Battery or Battery Circuit on motherboard. If the light is solid on 3. Amber, then the battery is not charging, and is draining.
Also make sure the power socket on the laptop is not loose or damaged. If it is, then it will need to be replaced.
I hope this gets you in the right direction.
No power battery flashes 4 orange
If it is orange or is blinking orange, the battery charge is low or expended. Remove the battery and re-install it. Plug in the AC adapter and connect it to an outlet. Turn on the computer.
When the battery status light blinks green and orange, the battery temperature is too hot for charging. Shut down the laptop, detach the AC adapter, and allow the laptop and battery to return to room temperature before attempting to charge the battery.
If the battery status light blinks orange rapidly, the battery itself may be defective.
Why is my acer pc battery light blinking
Its a motherboard problem, it seems that is not charging the battery, try to remove the battery and use your laptop only with the power cord, after the light returns to normal, plug the battery and check if the problem persists. if the light goes orange again the battery is the problem or the motherboard is not longer able to identify the status of the battery charge. This is a common problem in Acer Laptops.
Acer 4650 Travelmate Black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
1helpful
Acer Traverlmate 3260 no power
If it doesn't work off the battery either.
The connection inside the Pc has gone,
$150/$200 to be repaired.
Will be good then
Regards
Richard.
1helpful
Help! Laptop is dead, no power
1.have you charged the battery long enough?
2.is your charger working?
alternatively it is possible that your charger pin is not receiving power supply. you will need to get it checkd.
5helpful
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
No switch on
Removing the battery for a long period of time is a huge no-no if the computer is not plugged into the wall
Plug it into the wall and try again
Acer 2303NLC
you need to charge the battery or connect it to a power source
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
