Need exploded view of right rear door panel removal for 2001 Pontiac Bonneville. Can't get to inside to see why electric window won't work.
These are bad about those Cable operated window devices .. If it is bad get on ebay and get one ordered its your best bet.. Just take a flat screwdriver and go around the bottom of the door panel and pop it loose and up the sides .. there might be a hidden screw or two in the middle around the handles.. good luck ..
Are you sure there are no screws under or inside the door handle ? if not try lifting the panel upward to see if it sets in a pocket to hold it . also pull handle out tword you and look in there to see if a 10 mm bolt is behind there also. got to be a way to release it . sounds like you are in for changing out one of those cable operated window regulators ? Remember ebay when you buy one they are alot cheaper than GM for sure. Jerry
SOURCE: Can't figure how to romove right rear door panel on 2001 Pontiac
rt rear door panel should be easy their may be screws in and around the trim panel check for little top covers take off and screws are underneath them. know when you pull the trim off its mounted by retainers so be careful pull at bottom and work your way to the top pull upward and then take off you should be able to see after that
Dear Heapful, I got all the plastic holders unplugged and the top of panel off but the very center of the panel is very secured and there are no screws visable from the interior side of panel. I call myself an advanced shade tree mechanic. I don't mess with any computerized things but anything else it's a go. I'm thinking maybe go to the Library to see if I can get the GM Exploded view of a 2001 Pontiac Bonneville Right rear door. I tried O'rielys for a manual But Haynes sold out to Chilton and Chilton uses a completely different model car for illustration and the fron Dr. side door which is totally useless for my make and year. Thank you again very much and God Bless you all, Faryle
what is holding it on
