Question about Optimus 16-665 9" Digital Photo Frame
Photos not appearing on frame
I added more photos to my SD card and now only a few show up. All the pictures on there are JPEG.
Today, I added photos to a 16GB SD card and the digital frame is indicating that there is no card inserted, when it is. Is there any way I can get the picture frame to read the new SD card?
it may be that the sd card is incompatible with your digital picture frame
It may be too large in capacity .....it may be the incorrect type of sd there are sd hc and ad xc at the moment
Jul 06, 2015 | Coby DP-772 Digital Picture Frame
Bought digital photo frame a700 as a present for 90year old. have photos of great grandchild on 2 different sd cards. can i put them on one card for the photo frame
Yes. Connect one of the sd cards to a computer and drag the photo onto your desktop. Now connect the second card and drag the photo onto the second sd card so that both photos are on the same card. If you have a mac, the sd cards will appear on your desktop. If you are using windows, I believe it shows up under your start menu and then my computer (though to be honest, I haven't used a computer with Windows in a while).
Sep 17, 2011 | Mustek PF-A700B Digital Picture Frame
Garmin Nuvi 1490- I have loaded JPEG photo's but none will show up in picture viewer. i have changed the file size to a smaller format, but nothing shows up. i have loaded images on both the unit and...
The pictures must be in the "JPEG" folder of either the GPS's internal memory or external SD card to display. Acceptable formats are: JPEG, BPM, GIF, BNG, TIF, and others.If you are having trouble, resizing and / or reducing the number of colors in the picture may help. If you save or convert the image to GIF, it will automatically be reduced to 256 colors.
Sep 12, 2011 | Garmin nuvi 1490T GPS Receiver
How to load pictures to the frame
place images etc in any of the following formats
Supporting formats: jpeg,exif, mov,avi,mpeg1,mpeg4.
on one of the following cards,
Supporting cards: SD,MMC, MS,xD, CF,MD.Remote control. USB, 128Mb integrated memory.
or via usb cable onto the intergrated memory
when connected to pc and switched on will show up like a new harddrive or stick.
move pictures to this drive and they will be on frame internal memory.
or move images etc to sd card or usb stick,
insert card or stick into relevent slot or port on frame and switch on
images should be able to be viewed.
I hope this was useful.
Jan 24, 2011 | Kodak EasyShare SV811 (8858946) Digital...
Pandigital Photo Frame - Slideshow leaves out Photos?
Size limit depends on exact model. Anything over 4GB will almost certainly not work consistently with any. model 1GB or less should work with any model. None of the images should be stored in folders, and all should be jpeg format (.jpg). If any of them have been edited, they may be saved as Progressive jpeg or something similar even if the extension (.jpg) remains the same. If you resave the missing photos in as JPEG in MS Paint, it should ensure they are compatible. You may have to format the memory card and re-add the photos to make sure it will work,
Sep 20, 2009 | PANDIGITAL 7" Digital Photo Frame With...
I have a Innova photo frame. My pictures are on my usb flash drive (card). I have 21 pictures on the flash. Only 12 pictures show on the photo frame. I tried deleting all pictures and putting them back...
This photo frame will only support jpeg files. Other formats can't be displayed as show up as a red x. Also, the picture is 800x600 so larger formated files may not display correctly either. Remove the SD card and look at it using your PC. Check that all the files are .jpg - if not either replace or reformat them to be jpg and it should work fine.
May 11, 2009 | Computers & Internet
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Card read error on the digital picture frame - brand new. I bought this 7" digital photo frame from argos and I insert the SD card whilst the device is turned off, when I turn it on the message reads...
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Dec 12, 2008 | PANDIGITAL 7" Digital Photo Frame With...
Hi, i can only copy some jpeg images to my 8FF3FP digital photo frame and not others, any ideas why???
it only will show jpeg images no other formats show.
Technical information sheet of 8FF3FPB/00 - 8" (20 cm) Digital Photo Frame - Black + 1GB SD Card With the Philips 8FF3FPB/00 digital photo frame, you can show off all of your favourite digital photos in style!
Its 8" 4:3 screen has a resolution of 800 x 600 pixels, so with the 8FF3FPB/00, you don't need to resize your photos. Plus, the 8FF3FPB/00 uses ImagEn technology to ensure your photos always look their best on this clear, bright display.
The Philips digital photo frame is also an ecological choice, because its SmartPower function allows you to save a considerable amount of energy.
General Device Type Digital photo frame Key Features Digital photo viewer, memory card reader Width 24.5 cm Depth 12.1 cm Height 16.7 cm Weight 494 g PC Interfaces USB Features Auto power off, clock, USB host function, alarm, auto power on Localisation Belgium, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Indonesia, Israel, Lithuania, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Iran, Pakistan, Romania, Thailand, Malaysia, Singapore, Luxembourg, Hungary, India, Bolivia, Uruguay, Honduras, Guatemala, Panama, Algeria, Morocco, Bangladesh, Philippines, Croatia, Kazakhstan, Slovakia, Slovenia, Korea, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Russia, Spain, Sweden, Switzerland, Greece, Turkey Display Display Type LCD 8" - colour Display Form Factor Built-in Image Aspect Ratio 4:3 Image Contrast Ratio 300:1 Image Brightness 250 cd/m2 Display Format 800 x 600 Status Information Card, firmware version, memory Display Features Brightness Memory / Storage Flash Memory Cards Supported CompactFlash Card type I, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, SDHC Memory Card Digital Photo Frame Operating Modes Landscape, portrait Features Variable slide show speeds Still images Supported Still images Formats JPEG
Nov 30, 2008 | Computers & Internet
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Optimus 16-665 9" Digital Photo Frame Logo
46 people viewed this question
Top Optimus Photography Experts
Steve Allison
Steve Allison
Ekse
Are you an Optimus Photography Expert? Answer questions, earn points and help others
