Nokia N97  Cell Phone Logo
Anonymous Posted on Jan 17, 2013
N97 solution of Hanging
My phone often hanging is that a software problem or harware problem
  • Anonymous Jan 17, 2013
    yesterday i went to a shop to flash the sofware but the shopkeeper said there is a hardware problem now what will i do.
Anonymous
Level 3:
Master:
  • Nokia Master 520 Answers
  • Posted on Jan 17, 2013
Anonymous
Nokia Master
Level 3:
Master:
Answers
520
Questions
0
Helped
71504
Points
1645
Hello::::::
mY Dear:
First:
restore your Phone Settings
IF problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
5 Related Answers
Anonymous
  • 124 Answers
  • Posted on Jul 21, 2009
SOURCE: my phone gets hanged very frequently.
its an software problem kindly change the software of your mobile
Anonymous
  • 1017 Answers
  • Posted on Dec 29, 2007
SOURCE: N73 Hanging Problem
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT-----DO NOT---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again. But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Do not reformat a mobile just because something has gone wrong and you know how to do it.
The damage is already done.
Anonymous
  • 150 Answers
  • Posted on Mar 14, 2009
SOURCE: Hanging and restart problem
You don't need an antivirus. Nokia cell phones run on the symbian operating system, and there are 0 virus for that operating system, because that is not how it functions. Hope that helps.
Please rate, thanks!
Anonymous
  • 85 Answers
  • Posted on May 28, 2010
SOURCE: hanging with my nokia 2630
hi, delete some applications you downloaded, pictures,etc on your phone so that your phone memory can have enough space to operate.
cheers
Anonymous
  • 5 Answers
  • Posted on May 25, 2011
SOURCE: Please give solution for nokia E63 software
Your software has been damaged,update the firmware.
U can backup with
Phoenix Service Software
1helpful
Frequenltly my N97 having hanging problem
Hello:::::
mY Dear:
First:
Secend Option:
*#7370# or *#7780#
Very Best Solution:
Jan 17, 2013 • Cell Phones
Phone hanging n97
Dear user,
Please try and remove any unwanted applications that are not from good software providers, too many apps running at the same time will also affect, press and hold the menu key to see how many apps are running , close / try to remove unwanted apps.
2answers
My nokia n79 is hanging so much again and again because of memory card 8gb tell me what can i do
Hi, backup your data s and format memory card. always dont store till the end of the memory available. your card may be corrupted.
My Nokia N81 8GB keeps freezing/hanging. If i then keep it switched off for a few days, it starts working properly only to give me the same problem after a few hours of turning it on. How do i rectify the...
IT is possible that the mother board has some errors in the harware and so there is a possibility that when the board works it tends to hang up . But before we can confirm on this we must check if the phone has hung up because of errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
My Nokia N97 mini is hanging very often, specially when I switch on the phone. To get it well staterd I have to switch off and switch on again several times.
It hangs on boot due to some bad application on the phone.
You can reset phone to solve the problem. Here are the steps:
1. Make a backup of your contacts and messages as they will be DELETED after reset. 2. Take backup of internal memory to pc and then format it. To format, connect it to pc as mass memory, right click on the mass memory in my computer and select format 3. Take your memory card out, take its back up to pc and format it also. 4. Now dial *#7370# and select yes. Enter your password. The default password is 12345.
It will reboot and will solve your problem. Restore backup and data back to memory card and internal memory.
It will solve the problem of hanging.
33helpful
7answers
Nokia n97 screen freeze
Upgrade your firmware to 11.0.021 and restore your device to factory settings. also dont install apps in phone memory. keep phone memory free.
2answers
Server system hanging
system hanging when i connect server system
My computer is hang & cannot formatt.
hi!!!
try to insalled properly all your harware
1. your RAM
2.AGP
3. Processor
or try to reformat
if is keep hanging on
may one of your device
may be damage
2answers
Computer hanging
Try starting in Safe mode and remove any new harware or software you have just added.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
