I have a TLAC-02255 22" Polaroid led tv. When the set turns on the screen went totally blue the as you would press buttons such as menu or guide. The boxes would pop up in a blur almost as if to fade
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 15 Answers
Return your TV ... There is a manufacturers problem with your TV ... Return it and ask for either a different one or for yours to be fixed ...
Posted on Jan 17, 2013
SOURCE:
SOURCE: No Signal - Input w/ Cable does not work
I have same problem with my polaroid LCD tv.... Im thinkin about renting a gun and buying a bullet to fix it :D
Posted on Nov 15, 2008
  • 5 Answers
SOURCE: black box pops up on screen
Turn off the closed captioning! Problem solved!
Posted on Feb 16, 2009
ginko
  • 19396 Answers
SOURCE: Polaroid LCD TV TLA-4641C
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
budmrtn
  • 11361 Answers
SOURCE: Blue LED light comes on but nothing else happens when turned on
It can be the main board or the power supply, look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Posted on Nov 28, 2009
SOURCE: just purchased polaroid TLAC-02255. when
Not a solution...but an "answer". First, you should call the tech support number and talk to them; but others have posted on this site (and I'm about to) that they're having the same problem (mine won't get cbs or abc stations). I was told, as was another poster on this site, that 'some tvs just don't tune into some stations).
Even though the tvs have built-in ACTS and a NCTS tuner (for analog and hd) they don't always work with external (rabbit ear) antenna.
ANother poster to fixya wrote that she's returning her set to Target...where mine was also purchased. I'm going to ahve to box up ours also and return it, a shame since it was a gift!
Posted on Jan 05, 2011
How do i use as a pc monitor?
Well if you have an HDMI output on your pc you can use that or if the TV has a VGA input you can use a VGA cord and select your TV input to PC
Apr 06, 2015 | Polaroid TLAC-02255 22AA€A LCD TV...
We have a Phillips plasma tv and the picture pixelates randomly and freezes for about a second and sound breaks also. We have had everything checked and have been unable to find a solution. The latest...
In my openion, Its problem of hardware in your TV and signal processing circuits are involved. It might be problem of Firmware (programe to control the performence over all) Philips can advise you better in this regard.
Aug 01, 2008 | Televison & Video
Blue screen need to know how to scan channels to get input to come back up
Will need to know what tv you have, but you are right it is probably your input button. if you pushed it on your remote then there should be an input button on remote. otherwise you will have to go into the tv menu and setup it up there.
if you respond with model and make of tv, might get more info.
Jul 12, 2012 | Polaroid Televison & Video
Just bought a Polaroid 22"
I have a problem with my polaroid TLAC- 02255 aswell mine didnt come with batteries for the remote or TURN ON!
Dec 23, 2010 | Televison & Video
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
The guide button will not bring up the menu
Sounds like the disc player went bad. Polaroid has been having trouble with these players for some time. Call polaroid and check to see if this is a warranty issue. I have fixed these for polaroid before and the service call was comped. Easy change out, only takes about 15 minutes. Hope this helps. J
Apr 09, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Televison & Video Logo
547 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
