Hi, i cannot get my 945GCT-HM (Livermore) Motherboard to recognise a Sapphire HD-7750 Graphics card. Any Ideas? Thanks Lou Parun
Check primary graphics adapter setting in bios (should be pci not onboard) and check if the card needs a power supply connection
Thanks for your reply.
I have set this to PCI-E in the bios, soo this should have picked this up. My options are, On-Board, PCI and PCI-E. I guess I should be asking what Graphics card is best suited for this motherboard.
as the Sapphire HD-7750 graphics card may not be suited to the motherboard. ?
SOURCE: what graphics card this motherboard will support
Here is the link to the product support page for your motherboard; http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1732 The motherboard includes an Intel Extreme graphics card built in - the necessary drivers are available throught the link above. Here is the link to the manual for the motherboard if you need it; http://europe.giga-byte.com/FileList/Manual/motherboard_manual_ga-8i865gvmk_e.pdf Page 1 gives all the possible expansion graphics cards you could use - the gigabyte AG325(G) is recommended. Hope this helps :)
SOURCE: Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
SOURCE: Graphics Card Compatibility with Asus M2A-MX motherboard
Hi Anli!
Well, any GPU with pci expess will be compatible thit that mobo of your.
Its not easy to recomend any specific, it all depends of what you needs are.
Just make sure that the card you upgrade with is for an pci express slot.
A verry good GPU coast around 150-200 euros, a top GPU card cost 400-600 euros
There are ATI cards and there are Nvidia cards, both will suit with your MoBo as long as they are for pci express.
Good luck with your new card M8!
please take a moment and rate my answer
Nic
SOURCE: I need a sound card Driver
is this what you need?
http://www.drivershq.com/Drivers/HP/Compaq-Presario-SR/SR5210NX/566/37508/39261/Drivers.aspx
Check it out, ya might find just what ya need! :)
Joe
