I have the same problem, PC connection works fine, but no signal from HDMI connection to set top box. Cable works, brand new tested from same box to a Visio 32"I have the same problem, PC connection works fine, but no signal from HDMI connection to set top box. Cable works, brand new tested from same box to a Visio 32"
You can't post conmments that contain an email address.
try unplugged all units involved---HDMI does not like being hooked or unhooked with units powered and or on.
Wait a while and make the connections and then power set, box, whatever is inline back---the units will try to reboot and that may cure the issue- it is worth trying
Tries tv and cable or satalite boxes unplug,replug it back for like about an hour later.By letting tv resetting itself back to the factory setting and those pay boxes upgrading it softwares.The tv HDMI signal for the tv incomming broadcasting signal should be back,if not, tv might have a dead HDMI cable or that the HDMI 1 hub it plug in is shorted and dead.
I have the same problem. It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video). Video and audio cutout is random and drives the family nuts. I am desperate for a solution.
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663. So HDMI output setup on the 663 should indicate image only, no sound.
