La Crosse Technology Ws-9002u-camo Wireless Camouflage Thermometer- Logo
A
Anonymous Posted on Jan 16, 2013
My ws-9002u thermometer outside reading doesn't display,but inside does.what is problem?
My temp setting does not match my output temp
I have a recurring problem with a GE Profile PSB48LSRABV. Here's an example sequence:
  • Fresh food compartment set to 37F on the control panel (for months)
  • Thermometer in fridge reads 46F (with lots of water inside per manual)
  • Press "Display Temp" button, display shows fridge at 37F
  • Turn power off, count to 15, turn power on, wait for control panel to boot
  • Press "Display Temp" button, display shows fridge at 46F (matches thermometer!)
  • Compressor runs and cools fresh food compartment
  • Hours later thermometer in fridge reads 37-38 (yeah!)
  • Press "Display Temp" button shows fridge at 37F
  • Within days, the fridge is warmer inside again, thermometer inside reads 45+, but display reads 37 - unit needs to be "rebooted" again!
Fresh food thermistor from top of cabinet measured properly in ice water (and warmer water), the unit has always passed all the self-tests, and condensor coils and fan are clean, so I had techs come give it a shot under home warranty:
  • Trip 1 - Tech came to assess, ordered new evaporator fan
  • Trip 2 - Replaced fresh food evaporator fan (note new fan is working in fridge, and old fan works fine on bench)
  • Trip 3 - Ordered main computer PCBA
  • Trip 4 - Replaced main computer PCBA
Unfortunately, it continues the same cycle of misreading the temperature until power cycles, and taking a day off of work for each visit is getting painful.
Any ideas?
La Crosse Technology WS-9160U-IT Digital Thermometer. The outside temperature stop working. I tried new batteries.
Question edited for clarity. Full 'make model (what it is)'.
Did you put batteries in both units and in the right order, sensor first?
Step 1: Insert 2 fresh AA, batteries into the TX29U-IT sensor according to the polarity marked in the battery compartment.
Step 2: Insert 2 fresh AAA, Alkaline batteries into the wireless thermometer according to the polarity markings. Step 3: After 5 minutes place sensor outside in a shaded location.
https://www.lacrossetechnology.com/products/WS-9160U-IT#support
Retired unit so no further warranty or parts.
You can still get one on Amazon
La Crosse Technology WS-9160U-IT Digital Thermometer ...
Amazon.ca https://www.amazon.ca > Technology-WS-9160U-Digita...
Digital thermometer with wireless remote and clock; Remote sensor transmits from up to 330 feet; records daily high and low temperatures; Receives weather ...
Rating: 4.4 · ‎ 7,970 reviews · ‎ $31.50 · ‎ In stock
PSS26SGPASS Refrigerator is freezing food??
Find your temp settings inside the fridge and adjust. It takes 24 hrs to set to the new settings. If the controls are on the outside like mine then don't believe the display. Get a thermometer and put it inside. I have to keep mine at 42 outside display, any lower and it freezes the milk and veggies.
2answers
Outdoor thermometer reads -40 so the climate control system blows heat in the summer
sound like faulty out side air temperature sensor located center radiator support.
After changing batteries in both the outside sensor and the inside clock I no longer receive a reading for outside temp.
I have a thermometer with an outside sensor. It's necessary to remove both batteries, wait a few minutes, then replace batteries - sensor first. It may take a few minutes for the inside clock to pick up the signal. If it doesn't, try again with new batteries.
15helpful
2answers
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
41helpful
BIOS Digital Wireless Thermometer 312BC SETUP INSTRUCTIONS
I have a BIOS wireless indoor/outdoor thermometer. The indoor base unit doesn't display the outdoor temperature - it is blank - however the other temperatures - humidity, indoor temp, etc., are displayed, What is the problem? We have misplaced the manual so we don't know what to do.
2helpful
2answers
Thermometer not reading correctly
I would guess the outside thermometer has lost its calibration.
Does it seem consistently 5, 10 or 20 degrees off all the time?
Let me know.
Regards,
13helpful
Outside temperature thermometer on 2005 Ford Freestar van
my thermometer is blinking -40 degrees how can i fix this
Top La Crosse Technology Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
