I need to download the Brother MFL-Pro Control Center as my CD is broken, where can I do this from. ?
N
Here you go
http://www.brother-usa.com/SiteSearch.aspx?sk=DCP%20130
here you go,
http://welcome.solutions.brother.com/BSC...
itle:
The "Brother MFL-Pro Control Center" or "ControlCenter2.0" does not pop up when a document is placed in the ADF unit.
Description:
First,
please verify the Brother Resource Manager software is working. If the
software is currently running a street light icon will be on the bottom
of your desktop (see image below). If the icon does not appear scan
from another application (i.e. PaperPort) or restart your computer to
activate the Brother Resource Manager. Once the software is activated
the Brother MFL-Pro Control Center or ControlCenter2.0 will pop up
automatically.
If
the issue still remains, please determine if you changed or updated the
driver originally on your computer with a download from the Web Site.
It is possible the incorrect update was installed on your computer. If
you did change or update the driver originally on your computer, you
will need to uninstall the current driver and reinstall the previous
working driver by following the instructions below:
Driver Uninstallation Steps:
NoteIf
you are a Windows® 95/98/2000 user, this procedure deletes both the USB
driver and Parallel driver even though you selected only one.
Please click here to download the Uninstall Tool to remove the drivers.
The Brother End-User License Agreement will appear. If you agree to the terms, click I ACCEPT.
Save the file to your desktop
Double click DelInf_x.EXE and extract it.
A new icon named DelInf32.exe will appear on your desktop. This is the Uninstall Tool.
Double click the DelInf32 icon and the "Brother MFC Uninstaller" will appear.
Select your model and connection type (USB or Parallel) then click OK.
" Complete" will appear. Click OK.
Restart the computer. The Brother Drivers have now been removed.
Unplug the power cord of the Brother machine AND the USB or Parallel cable before re-installing the software.
Driver Re-installation Steps:
Please verify the version of PaperPort that is installed on your computer. It will be ver.8.0 or ver.9.0.
(You can check which version of PaperPort you are using; click:Start->Program->PaperPort->Help->About PaperPort...)
Create a folder on your Desktop and title it BROTHER. This is where you will save the downloaded driver.
Click "Download" to download the appropriate driver.
For PaperPort 8.0 Users:
OS
Driver
Windows® 98/Me
Download
Windows® 2000
Download
For PaperPort 9.0 Users:
OS
Driver
Windows® 98/Me
Download
Windows® 2000
Download
Save the file to the "Brother" folder you created on your desktop.When the file has finished downloading, open the "Brother"
folder on your desktop and double click the the downloaded file and
extract it. Connect the FAX/MFC/DCP to your computer with a Parallel or
USB cable and turn on the FAX/MFC/DCP by plugging in the power cord.
When the "Found New Hardware Wizard" screen appears,click "Next".
Select(Recommended) and click "Next".
Check "Specify a location" and click "Next".
Click "Browse" to locate the the Brother file on your Desktop.
Specify the same directory that you extracted the file to and click
"Open", then "OK".
Make sure "Specify a location" is selected and click "Next".
Click "Finish".
You may need to repeat STEPS 11 to 13 depending on your OS and Interface.
Thanks, but this did not show me where I can download the software, it eventually took me to lots of software downloads but not one called MFL-Pro Control Center.
Any suggestions on which one I select. ?
N
hi there, here you go
http://www.brother-usa.com/SiteSearch.as...
