The ice maker is hooked up and it is making ice, but the dispensers aren't working. Also, the light on the dispenser was working, but now it isn't
We have a similar fridge were told that it has a resivoir inside that needs to fill with water before it will start to dispense water. Had to stand holding in the actuator for quite a while befrore it started putting out any water. Shoud be the same with the ice maker, but there is an arm inside the freezer that controls how much ice you get it could be turned off.
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
