My dryer has the same problem. The dryer is set for 60 minutes but it will run for approximately 15 minutes and then stop with the "Ad" code on the display. The clothes are cold and appears that the heating element has not engaged at all.My dryer has the same problem. The dryer is set for 60 minutes but it will run for approximately 15 minutes and then stop with the "Ad" code on the display. The clothes are cold and appears that the heating element has not engaged at all.
Why does my dryer always destroy my familys clothes by getting stuck between the drum and the outer liner? Why does my dryer always destroy my familys clothes by getting stuck between the drum and the outer liner?
I believe that code means auto dry. Lets make sure the lint and dust is clear from the machine. Check all of your wiring out well since is generally a cause. You may ave to replace the thermistor. Have you gotten any other code along with this.
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
You have a blockage in the external connecting vent. Remove the vent and run a load.If it is dry in 60 minutes or less,repair the vent and remove the blockage.
This indicates there is an error with the door lock mechanism. It will most likely need to be replaced. This will prevent the dryer from working and is a safety feature to prevent injury while the dryer is in operation. It is fairly quick and cheap to repair.
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Check your lint screen. If you do not get a complete "lint pattern" you probably have a clogged or partially clogged vent which will cause your dryer to overheat and prematurely shut off. Clean your vent and you'll return to normal operation. If you have a vertical vent (goes up through the roof) get a proffessional to clean it. Dryer vent issues are the #1 cause of house fires according to the U.S Department of Consumer Affairs. Over 16,000 per year.
same problem ad code clothes wont dry
My dryer won't dry either and all lights are on.
Is there a heating element maybe that we need to replace?
